A Study of DMLs as a Full Range Speaker
Glad that my curiosity has been helpful. The shape of the panel seems so counter intuitive to me for preventing the corners from flapping. Hard to shift gears and get into a different mindset with dml panels. So are you suggesting that more shallow curves on the panel side might be an improvement? thanks.
The corners of the canvas are limited in movement by the wooden frame itself. The shaped Nidaplast's 'fingers' extend into those corners, and are glued down quite solidly. Therefore, the tips of those fingers are fixed points that don't move at all. The gradually-increasing width of those fingers means that the panel is progressively damped closer to the tips. If the panel was not mounted to the canvas, and was not mounted by its corners, then the corners would have to be rounded off to control the undamped vibration.
  • Thank You
Reactions: 1 user
Hi Andre,
Cool idea . 👍 Similar to Steve's canvas suspended ply panels
For the corners, have you tried inserting a radiused fillet in each to 'soften' them in stress/deflection terms??. It may allow the peaks in the Nidaplast insert to be reduced
Eucy
I used the canvas specifically as a high compliance "surround" to allow the panel to move freely, but yet not in an uncontrolled manner, in order to improve the bass response. In my Twinwall gig panels I had the panels clamped down all around, and this reduces the bass response significantly.
I'll do further testing and try to optimize the whole canvas setup to mimic a high-Qts open-baffle driver—a driver such as the Eminence Alpha-15a. If I can get the cheap Alpha-15a driver to deliver an almost flat response down to 45Hz in a completely open-baffle configuration, then there's no reason I can't get a panel, with a larger surface area, to do the same or better.
The only thing that I'd have to address is the inevitable suck-out at the first break-up mode.
Reactions: 1 user
Hi Andre,
Eucy
do you mean that rather than the corners going to a long point that they wold have a small semicircular notch at the end which would result in two smaller points at each corner? I hope this makes sense.
re the alpha- 15 was that slot loaded (front or bottom)? thanks.
https://drive.google.com/file/d/1kdh1yNhkZY9F1waNljSoVIBvRwwy2Uj0/view?usp=sharing&authuser=0
This is a link to Leobs panels doing a sound check 😄
I am very sorry for the very poor low quality of the recording 🤮
But I think it gives you the idea of the sort of sound eps can give.
Try and imagine this in a small venue 🫣
Eps is the most efficient material I know of so far, and can play realistic machine gun fire in my room ,at ear shattering levels.
This is with my 10watt exciters.
A random picture of one of my panels.
Why do I need EQ if I roll off the frequency at say 100hz ?
I suppose I could take a few db off above 10k if I felt it needed it.
Steve.
i think you knew i would ask which panel is that? thank you.
It sounds like we're barking up similar trees!
I've been using my panels for live gigs. I'm just a one-man with acoustic guit, bass guit, voice and backing trax. I use three drivers per panel—one 30HESF-4 and two 25FHE's all wired series/parallel. Plenty loud enough if I roll off the bass at about 150Hz and use a separate sub.
Yes, I found that as well, and it's a massive advantage in some of the venues I work. Instead of using multiple cabs to cover the audience, I can use only two panels and get ultra-wide coverage without having to worry about dead spots, lobing, combing, directionality, sweet-spots or any of the other problems inherent in using different drivers, with different response curves, pointing in different directions.
Nice thing too is that I don't need floor monitors because even if I'm positioned "behind" the panels, I can still hear the mix perfectly clearly.
I actually found less reverb problems, possibly due to the diffuse nature of the wave-front?
I use the panels with subs on stage. Of course, the 150Hz cross-over point takes care of the possible lack in that region if aligned correctly.
Also, when using cone speakers I almost always put a low-Q notch into the 200Hz region anyway to compensate for almost every indoor venue's upper-bass modes, and to get rid of the mud in the sound, and to bring out the vocals more clearly.
In the attached clip, I've rolled off the bass end for testing purposes while assembling the panels. .
You can see the perforated back panels standing around, waiting to be assembled into the frames. As you have, I've also mounted the drivers directly into the back for support purposes.
That sounds nice, I love Bob James. thanks.
Reactions: 1 user
The Nidaplast fingers are stuck into the corners horizontally between the wood and the canvas, and then glued solid. The tips of those fingers can be sharp or truncated or scalloped, it doesn't matter what the shape is because they're fixed points encased in glue.
Just a plain open baffle. No slots. No loading. No wings. A single 20mm thick plank just wide enough to accommodate the driver and high enough to screw a tweeter into.
  • Thank You
Reactions: 1 user
To me driver placement does not seem essential to what modes can be excited. The plate has its mode structure, and depending on where you place the exciters they will work more or less for or against the existing modes, and the effect is far from absolute. What surprised me was that moving around the clamping seemed to have more effect than moving around the exciter. I think that typically the plate suspension will be a lot more rigid compared to the exciter which is really only adding mass making the mode a little bit harder to excite.
And I don't think the exciter has to be at the peak of a node to excite it to the maximum excursion. It is similar to how a driver interacts with the air mass in a sub, where at some frequencies small movement still results in a lot of air movement at the port or mouth. The exciter ends up in a position where it basically gets leverage against the modes inherent in the plate.
Quote "To me driver placement does not seem essential to what modes can be excited. " please explain what you mean? the impact of the motor in whatever location you place it will have varying effects on the diaphragm which will vary with frequency as well as level and there will also be panel related effects which will also be variable. For every different driver location you have a different situation then adding multiple motors and it only becomes more and more complex. The motor and the panel combination is a veritable can of worms of back and forth interactions. It makes me dizzy to think about it.
Reactions: 1 users
Moray .
I just took a few pictures of some old test panels, which were lying around.
The first on the left is the back of my cascamite canvas panel with the enlarged crate ply attached.
I would have tried a larger crate ply but that was all I had.
Minimising the amount of loose canvas to stop flapping or buzzing.
I do not remember any problems with the corners?
The second picture is the front of this panel.
I had forgotten that I cut away the canvas from the panel to minimise the damping on the panel 🤗
Which was handy for the cling film , giving a mm or so separation .
3rd and 4th are of a crate ply with weights for this panel only.
Two points were used for mounting, plus some film for testing.
The last is an old 5watt (I think) exciter on a low density EPS panel.
Steve.
  • Thank You
Reactions: 1 user
Thanks I will have a look at these and give them some thought. I appreciate you posting them. do you remember how many card panels you made? I am still having a bit of a hard time adjusting to panel size and level with DML panels. one of your card panels was 6x9 inches so how much larger would a panel need to be to play appreciably louder than that one would (I guess I should ask hoow loud that one willl play with subs) assuming that the bass roll off of the larger panel was adjusted to match the smaller panel? I cannot seem to understand how small or how large I need to build. I would be happy with the ability to play average level of 95 db and peak capability of over 100 db db. I don't often play this loud but some music just calls for those levels to feel right. Is this expecting too much from a small panel? thanks Steve.
Moray.
The crate ply is a very flexible panel , in one direction only.
Although the rigidly in the other direction is not very rigid.
I presume this material is similar , maybe, to flexible ply ?
As I have said before, I like flexible light panels.
The sound of this panel is similar to my eps panels, but is still a little too heavy for that ultimate sound that I like.
And thanks for liking my recordings, much appreciated 👍
Steve.
with a drill press you could lose a lot of panel weight and see what that sounds like?
I'm not saying it has no effect, but that it doesn't seem essential. I cannot claim to understand exactly how and why, I just found that moving around the exciters does have an effect on the FR, but it is much more marginal than I would have expected. The properties of the plate and how it is suspended seems to pretty much decide the FR, and then you can do minor adjustments with for example exciter placement and weights.
  • Thank You
Reactions: 1 users
The driver will vibrate the whole panel and make sound regardless of being placed on a node or an antinode. I think this is why the placement of the exciter is more forgiving than the suspension of the panel.
If it made sound only from the resonance modes of the panel, the frequency response would look really bad.
It's true that DML panels make sounds at all driven frequencies, not just at the resonances. But they do tend to make sound more readily at resonances, and especially at some particular resonances that are especially good at radiating sound. And not only can they radiate really well (i.e. loudly) at those frequencies, they can also ring (i.e. resonate long after the originating signal is gone) at those frequencies. And for those reasons, sometimes the frequency response and spectrograms of DML's truly do look really bad! This is especially true at low frequencies, where modal density (resonances/octave) is low.
In my experience, there are basically two ways deal with this basic issue. One is simply to use a DML only above the frequency at which all the lumpiness and ringing disappears. Depending on your choices, this could be in the range of 300 to 1000 Hz.
The second way is to use good design principles to (a) distribute the natural frequencies regularly based on the aspect ratio, suspension points and elastic moduli of the panel (b) judiciously position the exciter to equally excite those resonances, and (c) add sufficient damping to spread/widen the resonance frequencies from individual sharp spikes, to broad humps that overlap. With this method, it's easily possible to obtain good frequency response down to 100 Hz and perhaps lower.
Eric
Reactions: 1 users
I got this from a 10"x22" (~25cmx56cm) e-glass'd EPS panel the other day:
The orange line was my first test in a new frame, driver unsupported, with angled baffles on 2 sides. Short side on top and bottom are supported full length. I'm still working on this frame, and the panel was a crazy experiment, but this LF is pretty impressive so I thought I'd share. Approximately 10"x22", 10mm thick, 185g.
Sapphire,
Wow, big LF bump with the baffles. Nice to see data! Can you share any pics of the panels and baffles? I've never tried baffles but have always wondered about whether simply making the panel bigger (self baffling) would achieve the same or better result than adding the baffle. Any thoughts?
Eric
from the description of the anti nodes in the patent Spedge was just talking about if you could see where those anti nodes are then perhaps you could laminate a layer of very tin aluminum film say a half inch wide which overlapped the anti nodes and attempt to smother them? or if they were spaced far enough apart then simply spot damp them with a constrained foil layer? Just thinking out loud here.
Hey Moray,
I could be wrong but I'm not sure that you can really do much with localized application of CLD. Frankly, I'm skeptical of any treatments attempting to address individual modes, and even more skeptical of treatments for individual antinodes. I prefer a more wholistic approach like I described in an earlier post tonight.
One possible exception would be the use of local weights for the purpose more evenly distributing natural frequencies along the frequency spectrum. I have not tried this myself, but for me this would be similar to using shape, or aspect ratio, or elastic properties to tailor the distribution of natural frequencies. But it would take modeling capabilities (like LISA or better) to do decently.
Eric
Reactions: 1 user
Sapphire,
Eric
I used some scrap chipboard to make an L that I mounted to the back of the frame. It's about 15 inches deep and runs a bit further than the length of those 2 sides. I used duct tape around the entire panel-to-frame gap for a seal but I don't think that worked very well so I'll have to figure something else out. The frame is made of 2x6 so it's already got at least 6" of baffle built in all the way around. This was my first test and I haven't had time yet to experiment with baffle sizes. Building a driver brace is a higher priority right now, as is my day job... :p
Bracing the two short ends of the panel made an improvement by itself but it was a bit lumpy. The baffles added more and smoothed it out.
I never really thought about baffles in the past because the panel itself looks like a baffle (self-baffling), but there's a lot of interaction between the front and back near the edges. The smaller the panel the more intense that is. You can feel it in the air with your hands near the surface and hear the weirdness with your ears if you inspect the edge of an unsecured panel while it is playing. I figure that baffles should dilute that front-back interaction resulting in higher efficiency and less distortion.
