F5m kit
Yeah, that's pretty much it, "Transformer Chassis Seat". It's super secure as is (I can pick up entire chassis by grabbing the donut) no need to redesign for this amp. Happy to share the STL file for others to try. The pipe strap was $2/ea (I bought a 12 pack). So, under $4 total cost for app the parts: M4 bolts/nuts, fender washers, 42gr TPU material, and the strap. Of course, you need access to a 3D printer that has direct drive for TPU prints.
  • Antek Chassis Mount AS-3218 Ver-3-12-24.zip
Reactions: 8 users
The pipe strap is an excellent idea! Sadly I don't have a 3D printer. I might figure something else out!
@Jacruzer787
My backup plan for mounting the transformer vertically was to use a Simpson Tie (L-bracket) from a big box hardware store, and just drill some holes to mount to chassis perforated plate and the bolt that comes with the transformer. Others have recommended that as an affordable diy option. The 3D printed idea just seemed a little cleaner, easier for me to do, a fun design challenge, and slightly less expensive.
There's always a 3D printer house that will do it pretty cheap, or you find a Makerspace near where you live, ask your buddies buddies if they have a 3D printer (there are pretty common for "diy-ers" to have), or PM me and I'll hook ya up.
  • Thank You
Reactions: 1 user
Joined 2009
At the cap and inrush limiter it looks like the safety distance between live and chassis is too small. Maybe put a piece of Mylar under the screw terminal if you insist on that arrangement. You know what you are doing but someone less skilled might copy.
Reactions: 1 user
6L6
Moderator
Joined 2010
That’s a good idea and will do. (y)
I’m not 100% in love with this arrangement and should come up with something a little better, including insulating all the legs. The safety cap might be better installed on the PEM, which would make the terminal block wiring even simpler… will think about it a bit.
Reactions: 1 users
