100W Ultimate Fidelity Amplifier
Hello ! First , thanks Alex MM and Apex for brilliant schemes and pcb.I managed to finish the P30+TB3 amplifier.
Reactions: 11 users
Joined 2003
TB-3 tone controls are fabulous!
I'm correcting the overall rising speaker response of small midbass driver. I'll try it with a pass full range eq. This driver still need cone break up attenuated!
My plan is to install it in an integrated amp along with Apex AX11 mini
Reactions: 2 users
Joined 2003
Hi all,
referring to the REV3 scheme of #14,268 - I wanted to know about the 3 potentiometers (bass-mid-treble)
are they lin or log?
many thanks,
Marco.
I'm using linear.
This one fits. I would like to find other options for 10k linear that will fit the pcb
https://www.digikey.ca/en/products/detail/bourns-inc/PDB182-K220K-103B/2564759
edit - BTW, the Bourns pot has a center detent. The response is basically flat at the detent. From my acoustic measurements it looks like
an approximate 6db cut and boost
Reactions: 1 user
Apex BJT STEREO PRE-AMP SB 3.1 2014 - 2020
Hi guys I got this new layout I decide to go back a re-done the BJT pre-amp now that I have more experience I'm gonna posted here please if some one see an error let me know I just make it today I attached the schematic I use on simulation
Note: is not tested yet
Hi all,
In this preamp Apex SB 3.1 do the transistors have to be paired for a best result?
I think XRK made it and was satisfied.
