Frugel-Horn Mk3 Builds & Build Questions
Before I close the cabinet, does this look right?
10mm felt according to the blue
3x10g acoustuff in the orange and green area.
What amount can I expect behind the baffle?
My Frugel-Horn MK3 are finaly in place.
Build by 19mm MDF with oak veneer. Finished by vax-oil tinted with smoked Oak.
Deivers are TB W4-2142. The measurements are looking good, first measurement are in listening position, 2th are back close to the port. I looks like I can benefit with some deeper bas respons by adding a reflector behind the cabinets.
Hello PerCarlin:
Your speakers look nice.
I think you might consider adding a powered bass driver to augment the lower frequencies. Deflectors will help, yet it is unlikely they will bring up the bass very much. The issue is small drivers can only move a limited amount of air and are therefore limited in bass reproduction.
I hope this helps
Reactions: 1 user
frugal-phile™
Joined 2001
Whilw true, with the FH the room makes an even bigger difference given the room is used the last part of the loudspeaker.
Along Scott suggestion, when you menioned deflector i thot about the ones i have with a stealth woofer hidden in it.
dave
Reactions: 1 user
