Frugel-Horn Mk3 Builds & Build Questions
Great guys.
I'm building a modified Frugal 3 (mouth and driver facing front). I was concerned with all the baffle step circuits being used on narrow baffles.
Still going to try Rl's and a wider baffle as I need a spacer anyway for the Pluvia Sevens.
Much thanks, Zene
@Scottmoose you mean that the low frequencies that “wrap” the cabinet are reflected by the wall behind so not lost at all.
Generalised in the room given the wavelengths involved; as far as that particular aspect of what I was talking about goes, the mathematics are predicated on a free-space assumption and we don't live in free space, nor are our room constructions perfectly lossy, so in practice you rarely have as much effective attenuation at the listening position as the theory suggests. And then you also get the other points which I noted above.
Reactions: 1 user
Great guys.
Much thanks, Zene
That isn't a modifed 'Frugel [spelling] 3'. That's completely at odds with all the design principles / assumptions used in developing the Frugel Horns, so you're entirely on your own. It certainly won't function anything like intended, the acoustic low pass will be severely compromised, as will the general response trend as the acoustic impedance match will be significantly compromised and the curve mis-sized. I wish you luck, but it's not a direction I'd advise. Out of interest -why do you wish to reverse it?
Scott ...
It will not be run full range. Both bottom and top will be cut off. Straight horns covering down to 100 - 200 hz are quite large. Even LaScalas with excellent upper-bass are 8 cu ft, so I thought a Frugel type horn just might work. Length is vertical, not horizontal as we know, so front firing could give me the mid-bass I desire.
I have plenty to work with for bass. Top will be augmented with tweeters so I can control volume. Old and upper frequency hearing loss come as a package deal.
Hate to say (not really), but doing what everybody else does, even though tried and true, does not advance the sport.
Zene
frugal-phile™
Joined 2001
the usual mathematical derivation (4560 / baffle width in inches for a -3dB nominal) is just that: a mathematical derivation
A result pulled from observations of actual measurements by Olson & co of a limited number of shapes and given the dramatic roll-off of some shapes, it is only a first approximation.
dave
Reactions: 2 users
Scott ...
Zene
I'm less concerned with extension than the severe harmonic modes that will result through the upper bass and into the midrange (with rapidly increasing group delay) due to the severely compromised profile and acoustic low-pass, which in effect will be shifted at least 100Hz higher in frequency. If you want a front-firing horn, by all means use one -but I strongly recommend actually using one designed for purpose rather than trying to modify an enclosure designed for a completely different set of conditions.
The frequency is a -3dB nominal but (and it's a significant one) that does not necessarily mean you are -3dB down at that point. You would be if the driver was tracking a flat-line, but that is not always (rarely, in fact) the case. This is accounted for, which is why within the context of what they are, you don't find many people complaining about the LF on any of the FH series. ;) The only time it can be a mite weak in relative terms with the 'intended' drivers is with the older 126 series units, especially when used with voltage source amplifiers, but these were always meant as a side-option only.
SM, after all these years that is point that I never considered. Yes, the fact that you are not dealing with a straight/flat response to begin with can be substantial.
Kick them out 10 deg? What cavitation resonances are you referring to? If you are altering the design of the terminus, you are altering the designed loading, and I can't predict whether it will work properly any more without knowing the details of your new design. The terminus will likely need to be reprofiled and the expansion path length / tap location and choke dimensions redesigned to suit.
Zene, as Scott noted, basic skill with a jig saw should make simple work cutting the curved side panel. Indeed, several of “our” prototype builds were accomplished by rough cutting a 1/2” MDF pattern with jig saw, refining with belt and R/O sander. The plywood construction parts were also rough cut with jigsaw, then finished with pattern following bit on 3HP router.
As is often the case, every aspect of this deceptively simple design is functional, and to be honest, I found cutting the curves to not be the trickiest part of the build.
Of course, once satisfied with the protos, we proceeded with CNC machining of the side panels.
