I'm facing similar issues; can you please download user or service manual forI just went over there, maybe I can find what you need. What docs are you looking for?
Technics SA-380S
https://www.hifiengine.com/manual_library/technics/sa-380s.shtmlIt's not available on elektrotanya
Just tried to set up an account and I was told:
"Please turn off your VPN to continue"
Connecting from Germany. Thing is, I don't have VPN activated.
At the end of the day I understand that preventing abuse might be quite an effort. On the other hand ... too strict an automatism makes the thing useless. At least for me in this exact use case.
Technics SA-380S
they dont show a service manual.
only a brochure and an alternative brochure.
I had verizon service for years and it was never a problem to use that site.
Must be something else.
I PM'd it over at their sister site, vinylengine. some excerpts of their answers:
Unfortunately registrations are no longer possible from that Verizon IP range due to high levels of abuse. ...
Is there a workaround? ... Sorry no, not unless Verizon start responding to abuse reports.
I created an account using my t-mobile phone, but ran into the issues when logging in on my home internet (verizon):
the site will automatically delete the account on the next cron run if you tried to download from a blocked IP address. Otherwise what would be the point in blocking the IP range?
If some nice guy/girl could download thisone for me,please https://www.hifiengine.com/hfe_downloads/index.php?kef/kef_psw2500_service_en.pdf
And post it here, i would be glad.
Thanks,
Thanks,
Got all i needed here: https://elektrotanya.com/
Goodbye to HifiEngine , it is not worth it to be so paranoid.
Same story here (Germany), tried to register for months, was giving me „Turn VPN off error“, even i was not using any. Now suddenly my IP is blocked. From mobile network registration is not possible.
Got a nice Yamaha CA-V1 amp as a present, but service manual/schematic is only on hifiengine, did not find any at electrotanya.
Would somebody would be so nice and download it for me?
Thanks,
HiFiEngine does not allow external links to a file. You have to get it through their home page.
The KEF PSW-2500 service manual is attached here.
- Member Areas
- The Lounge
- What is going on with HifiEngine?
