An illustrated guide to building an F5
Joined 2005
I have a Deluxe 5U Aluminum chassis available. It does have a 18MM hole in the front panel for an on/off switch and two holes for LED's.
I'm happy to pass it on for packaging & shipping costs. Send me a PM.
Give me 100 bucks of tickets and that's a sealed deal. If I win I will auction/raffle again. For charity of course and there's many that can use it. (I can't have the chassis as much as I would love to, I'm too far away), But now I have started its only a small repayment for many years of enjoyment from this site. Many Thanks. Of course, should there be such a tombola.
The F5 is one really good sounding amplifier. I forgot what it was like to continue to sit in front of the computer doing nothing because I was still listening to music.
It is playing through little old Infinity speakers and they sound so much larger with the F5. When I first connected it I was amazed at the strength of the bass and thought that I'd probably have to adjust the subwoofer... then I saw I had the subwoofer off.
Reactions: 1 user
Dear all,
I am building the F5 amplifier using V3.0 boards from DiyAudioStore. The build goes fine, however, I have a question regarding the settings of the current in Mosfets.
For the JFETs, I am using matched ones from the DiyAudioStore. For the MOSFETS, I am using non-matched (I simply ordered 2 pairs via Mouser) IRF9240 and IRF240. At the moment I am setting up 1 channel.
I followed the procedure from the Nelson's article on F5.
I went so far up to the ~0.4 V on R14 and R13 trying to keep the bias offset below 30 mV. What I observed, is that with an offset of 25 mV my typical voltages are ~0.41-0.42 V on the N-mosfet and ~0.35-0.36 V on the P-mosfet.
Is it an acceptable difference? It is 60 mV absolute over 0.47 Ohm. Or is it really not fine and I should consider sourcing matched Mosfets?
Thank you very much for your suggestions!
Joined 2002
I personally wouldn't worry about it. The main thing is to get the final bias current, with the amp warmed up, in about the 1.3A range (~0.6V across the 0.47R source resistors) and with the DC offset close to zero.
And don't forget to short the inputs for this procedure.
Also in the case of IRFP240 and IRFP9240, they are sufficiently different that matching between the the N and P channel parts isn't really feasible.
