This list is not exhaustive, so please include stuff I've forgotten, other circuits, or favorites posts.
A babelfish'd version of the Aleph J. Standard parts.
About possible Babelfish J interest
Babelfish XJ
A babelfish'd version of the Aleph J with SUSY (Supersymmetry). Standard parts.
Babelfish XJ , or JX …….. or whatever (Aleph X servo for Greedy Boyz)
Babelfish J2
A babelfish'd version of the FW J2. IRFP150's for the OS transistors.
Babelfish ᄅſ....or FW J2 on Steroids .... or Not your Father's J2!
Babelfish M25
A babelfish'd version of the FW M2. Standard parts.
Babelfish M25, AKA M2 on steroids, AKA M2-XA25 bstrd AKA M2 gone Berserk
Babelfish M25 R.2
A babelfish'd version of the FW M2. Standard parts. Different biasing scheme.
Babelfish M25 R.2/SET amp
Babelfish XA252
A babelfish'd version of the XA25. SOT227 OS parts, SITs optional.
Babelfish XA252 / Babelfish XA252 SIT / Babelfish XA252 SET
Boo/Pooh
Square Law PP Follower Stage, bridged or not (which are going to drive even F4)
The marriage
Il Penitente
A complimentary BJT amp, with iron FE
Il Penitente
LuDEF
DEF amp topology w/ LU1014 power JFET
LuDEF
LuDEF P
DEF amp topology w/ LU1014 power JFET – active FE (Plethora of Pinjatas)
LuDEF P
Old Soul
Germanium output transistors; BJT outputs also possible.
Old Soul
Plethora of Pinjatas/SET P
Square law OS. ZM active FE. Standard parts. Schade option (SET)
Plethora of Pinjatas/SET P amp
Singing Bush
A variation on the SE 50W amp Nelson presented at BAF 2015. SIT version; MOSFET version w/ schade
The Singing Bush
Lazy Singing Bush
A SE 50W follower amp – mu-follower arrangement. SIT, MOS, etc
Lazy Singing Bush
Choked Singing Bush
A SE common source choked amp – USE QUALITY IRON
Choked Singing Bush ..... special one for Purists and Masochists
SissySit
DEF amp with SIT and MOSFET
SissySIT
SissySit R.3
DEF amp with SIT and MOSFET; New biasing scheme
SissySIT R.3
SissySit P
DEF amp with SIT and MOSFET; uses active FE (Plethora)
SissySIT P ..... or how I proved fact of making more Hats than Pa did
SissySit (42)
DEF amp with SIT and MOSFET; fully DC coupled; footprint for K2087
K2087 musings phase two: SissySIT 42 as a cradle
Scryer
DEF OS with single common source JFET FE; fully DC coupled; footprint for K2087
Scryer ..... or how F8 met Mighty SissySIT
Steeplejack
single common source JFET FE; M25-style OS w/ Schade FB
Steeplejack ..... or how F8 met mighty babelfish M25
Stasis OS
Newly designed Stasis OS boards
Stasis Front end
Warbler
Choke loaded source follower; SIT, MOS, or Schade MOS
Warbler MOS Schade MOS SIT choke loaded follower power amp
Balanced transistor amp for swinging the likes of an F4
Pumpkin Preamp - Perfect for F4
Iron Pumpkin; Iron Turtle
Shunt reg + buffer + AVC
Iron Pumpkin(s) and other smaller vegetable animals
Iron Pre
Shunt reg + buffer + autoformer
What's wrong with the kiss,boy ?
PSM LS
Optical line stage
Poor Serbian Man
Easy way to cool Class A amps
Babysitter for Papa's Koan
D1 OS
I/V stage from PL D1 (Gerbers)
Pass Labs D1 Dac
Amps
Babelfish JA babelfish'd version of the Aleph J. Standard parts.
Babelfish XJ
Babelfish J2
Babelfish M25
Babelfish M25 R.2
Babelfish XA252
Boo/Pooh
The marriage
Il Penitente
Il Penitente
LuDEF
LuDEF
LuDEF P
LuDEF P
Old Soul
Old Soul
Singing Bush
The Singing Bush
Lazy Singing Bush
Lazy Singing Bush
Choked Singing Bush
SissySit
SissySIT
SissySit R.3
SissySIT R.3
SissySit P
SissySit (42)
Scryer
Steeplejack
Stasis OS
Stasis Front end
Warbler
Line-level
PumpkinBalanced transistor amp for swinging the likes of an F4
Iron Pre
PSM LS
Optical line stage
Poor Serbian Man
Misc.
BabysitterEasy way to cool Class A amps
D1 OS
Pass Labs D1 Dac
two iterations of Babelfish J, earlier - simpler one, later one made to be scale-able
dunno, that would be it, when speaking of things finished as project
*****things to come sorta soon , being in phase of final pcb proofing:
-Il Penitente (last of autoformer gain amps, Square Law all bjt OS)
amps with P suffix, meaning active FE iteration of already known ones:
-Plethora of Pinjatas (B. M25/SET with active FE with special name, origin of series)
-Il Penitente P
-Old Soul P
-LuDEF P
-SisySIT P
****things cooking:
-Babelfish XA252/SIT/SET US
-Lazy Singing Bush
-several complete preamps, none/moderate to huge gain and swing
life is fun ........ even if I need to squeeze time, to make Kudos amps for my self, I'm obliged to make
-Il Penitente P
-Old Soul P
-LuDEF P
-SisySIT P
****things cooking:
-Lazy Singing Bush
Which power amp is the easiest to build?
most likely Babelfish M25/SET
straightforward bolting of mosfet outputs, 2+2 simple trimpot operation per channel
If you're anything like me, you're always planning which ZM amp to build next. Moreover, you can't quite remember all the options. This list is not exhaustive, so please include stuff I've forgotten, other circuits, or favorites posts. For every project listed here, there's a plethora of variations, bits of advice, etc, and it would be great to get some of those here too.
Just thought it would be nice to have a 'collected DIYA works' kinda post. If one already exists, we can disregard this one. Another option is to use the forum's search (https://www.diyaudio.com/forums/search.php?searchid=24812661) though its not especially comprehensive.
Amps
Babelfish J
Babelfish J2
Babelfish M25
Babelfish M25 R.2
Babelfish XA252
Babelfish XJ
LuDEF
LuDEF
Old Soul
Old Soul
Singing Bush
The Singing Bush
SissySit
SissySIT
SissySit R.3
SissySIT R.3
Line-level
Pumpkin
Iron Pre
Misc.
Babysitter
Thanks, this is a good idea, is it maybe worth adding a note also of the main active devices and possibly power output at 8 and 4 ohms? Just a thought.
Zen Mod Blog – Buddha is everywhere…….
Tab always open on PC, phone, ipad
For all those other juicy projects and easy to find pics of stuff I’m trying to build
For sure. I’ll try and get some details added today.
Thank you Cody, though I think it a really useful long term reference for all, I did not wish to initiate a lot of work for anybody. Maybe others could help with their findings, if they have built any of these designs, making this an ongoing thing?
Personally I find ZM's designs easier to follow than most, what's also good is that they take account of parts availability. This type of information to me is desirable for any posted project be it power amp, pre amp, speakers etc etc. Many of the designs on DIYA are world class, some even world leading. It would be such a shame to loose them. Thanks to all that work so hard for the benefit of others.
- List of ZM projects
