L'Amp: A simple SIT Amp
Joined 2012
It looks like you have the current limit set to 1A on your lab supply (left side). The voltage on the left side is not maximum either. If you series the two channels of the supply I believe you need to set the slave (left side) to maximum and use the right side (master) controls to set your voltage and current.
Your heat sink is also small if you want to run high Iq.
The bulbs should be in parallel. Are these 120V bulbs (i.e. North America)?
the bulbs connected in parallel, like in your videos.
the bulbs are 220v, perhaps this is my mistake :spin:
Measure the resistance of one of those bulbs with a hot filament by hooking it up to your power supply with say 30 volts across it. Read the current drawn for your power supply. R=E/I.
for 30v on one bulb with hot filament i receive 0.17A
maybe i need put more in parallel.
Oh for 220V you need very high power. You need 10 Ohms resistance. For 220V that means you need 4KW bulbs, so I suggest you order 110V ones, you can also find them in Europe, mine I got from France. For this value you would get for 3A about 30V drop, which is about right, you need about half of voltage. OR you could use a nice 195T5 choke from hammond like me :) (and of course reduce voltage)
And again I strongly suggest to use the 0.1-0.25 Ohm resistor on source.
Also remember that for 3A and say 35V on Drain you consume around 100W on your VFET, I think you need bigger sink than that ob your photo.
i do not have 195 right now, but i have big 90v transformer and i order 120v 300w bulbs.
why? i can calculate the Id from Vds.
woody, thanks for the article
2SK182ES is 1KW part and I am running it at 500W right now but i have proper cooling. So he can drive it, as long as he has good cooling.
how you do that? how much vcc? and resistance?
i have 90vdc 2000va and big heatsink from my F5 amplifier
You want to use tis resistor so in case bias drops for some reason and Idss runs have time to react and it promotes stability. How do you calculate Id from Vds?
I use custom water cooling loop and i am at +22C delta from ambient.
I don't remember the Vdd because choke has minimal voltage drop and right now I am playing with other IXYS FET. On IXYS I have 49V Vdd and 9A current.
There may be some confusion about this part. It's my understanding that the 2sk182 is the 1000W part, it comes in a round flat package that needs a heatsink on both sides. But the 2sk182es is only a 500w part ! Here is a picture of the 1000w.
