It can support up to 2ohms stable at +/- 49vlts , just increase the inductor to 35uh
I tested with 33uh. But only change is tgat i used 1m instead of 10m on pin 2 to 1 of tl074. Will that hurt efficiency that much?. And did you do resistor load testing? What efficiency did you get?
I don't think it will do any difference in lower frequency response. But it surely will hurt frequencies above 1khz. I might be wrong.
yes thanks ,i tried 22uf and no noticeable change on low frequency
use all parts exact as at the schematic i told you, that is the 10m should remain 10mega . the inductance that is the one i saw has a significance change when increased. by the way what type of inductor are you using?
Indeed very simple, but notice that there’s no feedback loop. One has to consider its hifi-ness.
To all that has build it and since this thread has grew a lot, which schematic is considered the most "final" version? Or at least the most mature? For some definition of 'final' or 'mature'.
i still use the tl074 , the amp is nice but if you are making it make sure you use bc337,bc327 and tl074.
updates on my amp. firstly i rectified the transistor arrangement on the dcp section , then i removed the overcurrent protection and remained with the dc protect . (I should have used an optocupler at the ocp instead of the transistor. when i connected the ocp to the shutdown of the amp it had a bad noise interference.) the files below for the revised amp with only dcp
use this original schematic by etgale . it works fine .
please use 9540 and 540 fets
much regards . please post photos of your build.
hi all , i have made many pcb versions of this amp ,
i still stick to the original schematic in the above link.
the thing i found interesting in this amp is that it requires original tl074/084 and bc327 and bc337 . if you compromise in this area it will consume alot of current at idle an produce hf noise.
my question is can i use two lm339 instead of tl074/084 and which other transistor can i use to substitute bc337 and bc327
vvv vvv my current project vvv vvv
LM339 are comparators with open collector output. While they'd be faster, because of the nature of their output the circuit would need rework.
can lm324 work ??
hello all , i have made my latest version of this amp , i opted for a through hole ic due to challenges in getting a geniune tl074/84 smd . imagine the smd also have issue ,
A not original ic works fine in preamp,eq, crossovers etc , but can't work well in this class d amp ,
with this amplifier it works but the amp produces a lot of hf . but when i use a good geniune ic the hf noise reduces and the amp does not draw a lot of current
but a geniune tl074/84 works with no issues at all .
here is my project and pcb files . have fun fam
It is quite slow, but it doesn't suffer from phase reversal. Of all old opamps it is closest to a comparator.can lm324 work ??
I didn't have opportunity to sit and rework the schematic yet, sorry.
- Class D
- Ultra Simple Class D
