Joe Rasmussen "Trans-Amp" - 40 Watt Transconductance "Current Amplifier"
frugal-phile™
Joined 2001
The transamp is a current amplifier and should be compared to
First Watt F1 or F2, the only First Watt current amps.
But the flat impedance of the Elsinore Mk6 means that it cares not what the amlifiers Zout is so the comparison becomes meaningful
If the loudspeaker had an impedance more like typical speakers with XOs (ie all over the map) then your statement is valid.
That said, Joe’s amp is an inexpensive chip amp, i have heard its pre-cursor (designed an dbuilt by a buddy) and it is really quite excellent,
The F5 & J2 are discrete amps from the genuis of Mr Pass, neithe rof which i have heard, but i expect they would have an edge, albeit at a much greater entry price.
It is worth noting that the 4Ω output impedance of the F2 puts it on the voltage amp side of the cross-over point with a Zout closer to many SETs.
dave
music soothes the savage beast
Joined 2004
Joe, I know this is an old thread, but I hope you do not mind few questions before I burn few chips. I was recently experimenting with transconductance lm1875 amps, and they are all working fine and singing beautifully, so I feel the need to work with lm3886 next (because I have plenty).
Can one substitute lm3875 with lm3886, assuming correct pins are used, without any changes to the schematics in first post?
Can one put trim pot on the positive rail side if needed? Could one do trim pot between the rails, to make it universal?
Thanks!
Hi all and adason,
If you connect an electrolytic capacitor from 100 to 220 uF (best bipolar) between pins 8 and speaker ground, it does not generate an off-set imbalance and does not need to do a "DC trim". You must also use a 22k resistor between pins 8 and 3, at the output. It was JMFahey-Argentina's orientation for an LM1875 chip.
Current amp
Dear adason and all,
Sorry for the delay, I need to use google translator. This scheme works for the three LM chips. Two I tested, 1875 and 3875. Other components like the schematic Mr. Rasmussen. I already asked for your guidance for these current amplifiers: they sound great.
augustoriodosul, would this make more sense to be true transconductance amp?
feedback needs to read after the speakers
No. The DC feedback shall come from the output to have unity gain there (and then no need for a DC adjust). Your schematic is fully DC-coupled with the 22k which is simply shorted out by the cap at higher frequencies.
The "true-ness" of the amp is governed by the 470R parallel resistor and the parallel "snubber" R+C but it is way good enough the way it is for speaker driving. True current drive from DC to 20kHz (Z_out >> 1kOhm) is neither actually required nor a good design requirement to start with, and would be very hard to obtain anyway.
Joined 2004
No. 470R resistor does no create 'true-ness' of any kind. Its just there to protect wild voltage swings when speaker is unplugged while running.
When one is careful, it can be omitted, its shunt by speakers impedance anyway.
No. R+C 'snubber', otherwise known as zobel has nothing to do with current drive, its used to shunt high frequencies in any amp.
True key to current drive is 0.33R resistor.
Reactions: 1 user
