Photo Gallery
Koba, what's your experience with Kemet caps? I've alus thought of them as being a bit crap, yon green puppet frog keeps popping into my head too when I see them on Farnell. This is based completely on prejudice though, it's easy to get a bit sniffy about certain makes of parts if your not carefull.
Like the on/off sw, swanky and must have a go at the way you do your OPT's, anything that saves a few bob in that dept has to be worth a try.
Andy.
Love them. Never had a failure. There's a guy in the Netherlands who sells them on eBay for about 5$ a piece, and you can still get them through the usual channels, too. Those Kemet caps are the voltage doubler caps.
Here's the datasheet: https://content.kemet.com/datasheets/KEM_A4024_PEH534.pdf
The power switch is a momentary button connected to an "on off" board so it's got touch power.
Thank for the PSU details
Looks interesting, and expecting more photos of your build.
Thanks. It's my first build using a steel chassis and knockout punches instead of a step bit. Waiting on a biasing board which seems to be waiting to clear customs or the plane crashed into the sea. Then I will resume.
Getting further along...
Thanks, Joe! The only Chinese electros (Chenxing - top middle) will be replaced tomorrow with UCC when they get here, too.
Here's the top...
Just two wires (gNFB loops) left and the chassis electrical ground.
Today I had a chance to work my monoblocs... Nothing I've heard compares to these triode connected >110W RMS Sine @ 30Hz output amps by yours truly IMHO.
Pure bliss in a bad time.
All built in my little "shop" lol
Heres some pics of testing my DHT heater regulator.
This particular unit is 2.5-25V 0.5-5.5A i got boards that can more then double the heater current permissible. Its a voltage controlled CCS with a very long integration time, keeping the internal resistance of the regulator high.
The picture shows the measured ripple at 20V 2A out, my fluke 175 says its about 0.6mV RMS
I've measured for distortion using sinewave, squarewave, and sawwave on the scope. The 1W power band was usable from 6Hz to ~75kHz. The full power output depends on the tubes and transformers used, but the most powerful one's I've built look clean at 30Hz @ 110W and bandwidth extends beyond 50kHz.. The 10kHz square wave response is very nice, too. For 200$ These effectively make a 100W transformer. Try it for yourself and If you think it's crap you have transformers for your heater supplies.
I also fitted this UCC caps, changed the tubes from 6P36 to 6P45, and changed from VR75 to VR105 because they need more bias voltage. I'm quite pleased with it.
