A Directory of Apex Audio Amplifiers
Thanks.
Mile, do you approve the idea of bridging the A40 high power boards?
2 chips per channel.
I made 12, so I got enough.
Because you liked my sound some time ago, I made a video today with my other favorite amplifier.
It is made of garbage items. Discontinued by TVs and any appliances. I used a box of technic with arrows)))))
And for my new A40 I'll make new speakers with those Visaton.
YouTube
hi there i made A40 by following the schematic. pcb is my own design but i have some issues. offset pot is not working. there is constant high output DC which cannot be adjusted by offset pot. when pgnd is disconnected, there is about 1.5v. i connected the speaker and it gives output but 80% distorted. iam trying to figure out the issue but there is no improvement. i need help.
I don't know if this is the best place to post but I would like some advice/help with A40. I went ahead and ordered the PCB attached in the A40 build thread but it looks like there is a problem.
I have attached pictures of shorts on the front side.
I assume I should dremel away the top copper trace. (The gerber files in this thread have a top copper layer with one copper arc.) It looks like the amplifier will badly malfunction with the shorts to the bias trimmer and resistor.
Perhaps this post can serve as a warning to others regarding the gerbers in the A40 build thread. I hope that the amplifier works when assembled with these PCB after the dremel fix. The parts are fairly expensive for two of these boards so I hope the gerbers attached to this thread are good... If there are other problems with the gerbers I would appreciate a warning before I waste all the components and time assembling this.
re you sure that in Apex A40 exactly bd139 should be on the radiator? They are in the mode of diodes... Maybe those mje340/350 that are connected to them in series
