No doubt snake oil products are full of s**t.
Wires should be routed as straight as possible, no sharp bend. This to prevent synchrotron radiation.
Synchrotron radiation See Wikipedia.
Same for PCB tracks, one can get a better sound, cutting track corners so that electrons make less synchronous radiations running at curves.
One needs to be objective in order to see that everything is thoroughly saturated with snake oil. We live in such an era. Name any product you use, from a car to a mobile phone, from services to politics, and there will be tons of the best and fattest snake oil. Even in the cheapest aluminum wire, market experts will always explain to you why it is better than copper wire.
By the way, who was the manufacturer of snake oil? Giordano Bruno or those who burned him?
Now there's a sentence I never thought I'd read.He offers a remote dowsing service
It's given me an idea, though. Perhaps I should offer a remote telekinetic house-cleaning service? I will think your dust-motes and pet-fluff into oblivion from the comfort of my home, for only $199.99 Canadian per psychic housecleaning.
And for your further enjoyment, I offer up this absolutely brilliant small business: Rapture Pet Care Takes Care of Your Pets After the Apocalypse
-Gnobuddy
I guess that also means single-sided PCBs only. The sharp 90-degree bends at the two ends of a plated-through-hole via would emit far too much audio-damaging synchrotron radiation otherwise.Wires should be routed as straight as possible, no sharp bend. This to prevent synchrotron radiation.
-Gnobuddy
View attachment 782353 I borrowed one of these Geoclense units from a friend of a friend. The intended purpose is to 'harmonise' the radiations from household wiring. Turns out when plugged into dual wall socket supplying any audio gear the sound changes with marked (resonant) increase in bass. Just sayin'.
Dan.
Not sure if Dan is being serious or not
But I did find an interesting Choice review of the Geoclense - they actually substantiated one of the claims!
Geoclense Home Harmonizer review - CHOICE
Casting resin, green dye and wall plug from Bunnings, all in a soap mould.
I'd add a cap-diode-resistor rectified LED for a 'premium' version that you can not just feel working - but See that it's working
Not that I'm thinking of going into manufacturing either or anything...
People still want to believe, what's let if they start doubting everything? BTW, I do. Business is often synonymous with BS.One needs to be objective in order to see that everything is thoroughly saturated with snake oil. We live in such an era. Name any product you use, from a car to a mobile phone, from services to politics, and there will be tons of the best and fattest snake oil. Even in the cheapest aluminum wire, market experts will always explain to you why it is better than copper wire.
Freudian slip in their prose?
"Unlike other fake harmonizes".
Yes, I'm perfectly serious in my findings of the Geoclense affecting the sound of my audio systems.Not sure if Dan is being serious or not
Perhaps the Choice reviewer should have tried this test instead of spending his time coming up with his little jokes.....moron.
Dan.
- Member Areas
- The Lounge
- Funniest snake oil theories
