100W Ultimate Fidelity Amplifier
apexaudio,Tell me, please, what functions does the capacitor C13? Is it possible to simply connect the earth with a jumper? or do one solid?
(Highlighted it with red arrows in the screenshot)
You can use 10R resistor instead C13 for test module. Power ground and signal ground must be connect with separate wires to PSU if you do not want ground loop and noise.
i have used the same wiring but the problem is with mp3 module when it is driven with 5v regulator it gives noise even with filter. i tried to use 5v bulk converter but still the same issue. i have atteched the image of mp3 module and bulk converter i used.
https://ae01.alicdn.com/kf/HTB1nxbU...-Decoder-Board-Panel-Audio-Module-Support.jpg
https://www.elprocus.com/wp-content/uploads/Buck-Converter.jpg
Show me an image with the amplifier inside? What PCB amplifier did you use?
apexaudio thank you.
It all started when I decided to make my own, correct circuit Board instead of those that are in this topic. (printed circuit Board did 2nd time in my life-1st was TDA7294). And made a few mistakes:
1. transistors bc557 / bc547 in the Datasheet view from below, drew them upside down. It's easy to fix just by turning them.
2. So as not found mje340 / 350 decided to put their replacement 2SB649 and 2SD669, but mixed up pnp &npn. - )))
Now that everything is fixed, it still does not work. Maybe because something got burned (the smell was not) when started with an inverted transistors, or somewhere a faulty product. As luck would have broken multimeter, waiting for a new one. We'll have to solder and recheck....
This is my story-))) I Hope to achieve operation of the amplifier. Well, a few pictures
Good Luck! and have fun..;)
