I watched the video's but did not hear any news about the V-fet SE amplifier. I do hope it is coming.
Circuits are still being designed, with several candidates. They all
occupy 4 TO-3 holes per channel on a bar which fits on the larger sinks
in the store.
I have a couple things to wrap up, and then you can expect kits early 2019.
Last news
Was BAF 2018 V-fet kit information from Stereophile
Burning Amp 2018 Set For September 30 in San Francisco | Stereophile.com
Best regards
Last news
I forget about the promise of early 2019. Thanks for the reminder. I was hoping for some info at the BAF 2018 but I will use patience. I have been looking forward to the circuit and kit for some time now.
What to Do with Those 2SJ28's ?
Build a new class A of course
Get fews "new" ones to test , JS and JD-33 grade from vintage Sony Vfet amp.
Tell us more
My luck was find fews used 2SJ28 in swap meet from Mr. J Didden " Linear Audio " magazine director.
Sunday evening if free time I do vfet's test's and open boxes with two medium horn's
who is "the new brick's" for 3-voices bi-amplified system build.
Heavy weight Technics tourntable SL-7 included Greetings
The design for the new DIYaudio VFET kits uses one VFET per channel.
The N channel and P channel VFETs have separate artwork, and slightly
different performance.
Each channel goes onto a bar similar to last time which holds 4 TO-3
devices and mounts on the DIYaudio store heat sink hole pattern.
The output stage is a follower, and has a socket for different front ends.
Availability should be March or so.....
Of these 4 TO-3 parts, how manny are Vfets? (In parallel?)
Is there a simplified schematic?
No. It's going to be a surprise.
Very exciting. Thank you Papa!
I second that!
SIT input stage and “Beast of 451 JFET output stage”!?
Merry Christmas to Papa and all you followers, and thank you for both entertainment and sharing of knowledge.
Great News!
The magazine page attached looks like an SIT amp with an output transformer. Are you going to make one like that?
Ohhh.....even better. Much fun ahead.
TKS45F323 SIT is much easier to discover a meteorite in the house garden.
Esoteric & rare & exotic & cost new was ~ 570$ one pcs.
- What To Do With Those 2SJ28's
