TKS45F323 SIT is much easier to discover a meteorite in the house garden.
Esoteric & rare & exotic & cost new was ~ 570$ one pcs.
So, how many do you have Soundhappy?
Fews "UFO" 1KWatt's waits after my 2SJ28 DIY work is done next exciting future project's.
Vfet | Mosfet 35 Watts push-pull amp DIY schematic designed by Uda Hitoshi
Find this article inside of old DIY magazine and share with Vfetcionados
My audio upgrade horn's voice is charming What To Do With Those 2SJ28's
Now interested by 2SJ28 or 2SK82 new Single - Ended amp by venerable Mr.
Oh what the other TO-3's inside ?
No. It's going to be a surprise.
The design for the new DIYaudio VFET kits uses one VFET per channel.
The N channel and P channel VFETs have separate artwork, and slightly
different performance.
Each channel goes onto a bar similar to last time which holds 4 TO-3
devices and mounts on the DIYaudio store heat sink hole pattern.
The output stage is a follower, and has a socket for different front ends.
Availability should be March or so.....
Yes Papa please more DIY SE amplifiers Kind regards
I finally have all the parts. Transistor bar holds 4 T0-3's for one channel, and the
bar fits the the hole patterns on heat sinks in the diyAudio store.
Looking at my calendar, I think I can commit to a release in January. The quantities
will be very limited due to the lack of VFETs, but those of you who have some
already can get the rest of the kit.
Great !!
..more available Vfets?
Possible 2SJ20 NEC ( old named Tokin )
this one is perfect candidate for TO-3 format drilled T bar.
Verified genuine source 2SJ20 NEC V-FET Sit utilise une seule piece extremly rare!!! | eBay
Enjoy life is good
Possible, yes. Do you mean the 2SK182 / THF-51s?
Does Mr. Pass play with NEC 2SJ20 triode ?
Could be interesting alternative semiconductor for this Sony SE DIY build ?
Thanks for exciting kit news
Has anyone found an N ch device that plays nicely with the 2SJ28 for use in a DEF amp design?
Other than matching gate voltage in order to self-bias, what would the needed parameters be? Is finding a suitable candidate simply a case of combing thousands of data sheets to find one?
- What To Do With Those 2SJ28's
