Valve Itch phono
diyAudio Chief Moderator
Joined 2002
Build your inverse Riaa in good tolerance first and then its usable both with gen and meter/scope as well as with sound card and Arta FR test. Then play with all and decide what's better more accurate or easier good enough method for your phono bench tests.
Joined 2009
:up:
Salas is too much 0.47uF 200V FT3 for C4?
Joined 2009
My preamps have an input impedance of 100K.
Itch preamp 3.9uF & 100K Cut-off frequency fc = 0.4Hz
Itch 0.1uF & 820K Cut-off frequency fc = 1.9Hz
Itch 0.47uF & 820K Cut-off frequency fc = 0.4Hz
No good go higher than 01uF, using V-Cap coupling calculator.
Load Input Impedance (Ohms): 820000
Capacitor Value (µF) 0.1
-3db Frequency (Hz): 1.94
Optimal low frequency response (Hz): 19.41
If used 0.47uF
Capacitor Value (µF) 0.47
-3db Frequency (Hz): 0.41
Optimal low frequency response (Hz): 4.13
So no act as subsonic filter for frecuencies lower than 20Hz
