GB: Round #2; Fo-Felix EMI Filter for AC mains 120/230v; By Folsom
I will do a GB #4 once GB #3 is exhausted.
Until then just move the resistor or replace it if you are worried. There is no reason to replace GB #2-3 boards with something else when they work as intended, and can be made so the resistor wont be the secondary fuse for free or a few cents.
I would try without the DC trap. Once before on a rather different power filter it did not like a DC trap. The result was heat, however. But there is enough similarity between the two that I would give a shot without the DC trap first.
You are more than welcome to post pictures or diagrams, if we cannot quickly despatch the solution.
Finally finished my first Fo-Felix. My soldering skills could stand improvement but I think it'll work.
