Hi riritronic,
So, how does it sound? Nice, compact build.
-Chris
Suprisingly, it sounds very good, no buzz, no breath, just an high frequency residue but not audible, just noticeable on scope. I will perform distrotion measurement later.
Hi riritronic , nice, look powerful, were did you get your board?My first class D amplifiers; built with TL494 PWM controler, 2N50 output MOS 125kHz oscillator - 240W into 2 ohms.
Can found it on Amazon :
TOOGOO(R) 10 x Universel Breadboard Plaque Platine Carte d'Essai PCB Test Circuit 7x9cm: Amazon.fr: Bricolage
Universel Breadboard Plaque Platine Carte d'Essai PCB Test Circuit DIY 10x22cm: Amazon.fr: Bricolage
Joined 2009
My JLH1969 in an old repurposed CubePC case.
SMPS for power seperated with a suspended aluminium/composite board.
Just waiting on smaller speaker binding posts to finish.
I like it!
My Simpelstark+ build is progressing.
Both channels are mounted on the heatsinks and tested with my lab supply.
Running smoothly. Jeff has assembled the control board for me. Need to arrange the mounting frame for it.
Next steps - soldering 2 x PSU boards, then wiring everything.
Some pictures about my the latest version of my V4 amplifier. Power supply +/-40V, output power is 70W/8ohms, and 120W/4ohms.
Don't you know that Coke is bad for you? That looks like a killer bottle for just one person! Spilled Coke makes on heck of a mess too.
Looks like it will be a clean build, as usual for you and Jeff.
-Chris
Chris, I knew there will be some comments on that killer bottle
I'm careful enough with it
Sajti, a well-organized build with 2 x PSUs - nice work!
Very well done!My Simpelstark+ build is progressing.
Simpelstark....what version?
New version protection board by Jeff ideal for a dual mono,very interesting thing.
- Post your Solid State pics here
