Great work yoke!
BTW, what is this little pvc pipe speaker in the background. I am looking for something my wife could connect her iphone to in the kitchen...
Thanks Gregje
Those white ones are Anthony Gallo Due
thay are a little expensive but you can try ebay...thay come from time to time on ebayuk for nice price (that's how I get mine )
but you will nead an amplifier too...and a sub
My current system
I made a set of towers a few years ago. Standard ported design using bass box pro. Each driver has its own sealed enclosure. The whole speaker cabinet then has a 25mm (1") mdf outer with an oak veneer finish. They look great. Drivers are 8" Jaycar response units from about 10years ago. The sub driver in the bottom is a 4ohm car audio speaker. Each cabinet has a dedicated 250watt rms amplifier just for the sub. The rxv673 has a trigger output, which I used to trigger a midget, to turn the external sub woofer amplifier modules on. The tweeter/woofer use an 18db/octave home made crossover. Amplifier at the moment is a Yamaha rxv-673, but I'm about to pull it to bits. The power output of these new amplifiers is just no where as good as the older units. One look at the transformer inside tells me it's probably good for 100w/channel at best. I'm in the process of building a set of 175w rms amplifiers to be used as the main channel for this amplifier. So I'll be removing the main audio stage, and supplying this as an output to an external amplifier. I'm doing this so I can retain the Dolby surround, and all the cool Ethernet features this amplifier offers.
All in all the sound is great. Tight bass response, very balanced sound (without the sub turned on).
High power 3 way system with (12" 6.5" 1")
What kind of midbass/midrange is that ? Looks nice.
Great crossover design too.. seems to be very thoughtful, inductors nicely aligned not to disturb eachother.
Hello guys!
Here's a pic of my diy hi-fi room and diy speakers. 12 Seas 26 Lroy 10" up to 200Hz, and Seas Exotic full range in front.
I couldn't be more happy with the sound in this room
I've taken very much efford to make this room as a propher "listening room" as possible.
(Sorry for my bad English)
Back wall, with 60 cm isolation, and the floor too.
Finished back wall
Side and roof reflection traps
And of course, a diy turntable Denon DP 75 With MG1 air driven arm.
Diy turntable shelf
Finished back wall
Diy turntable shelf
Speakers.
Speakers are the Gryphon Trident speakers.
sorry for off-topic, does anyone recognize this WWMTMWW speaker in this picture:
Speedster
I just finished a 9.2 liter version of the Speedster. I re-purposed an old cabinet from an abandoned project. I wanted to use the cabinets as the veneering came out really nice. Veneer is raw anigre over an MDF followed with Watco natural Danish Oil and Minwax paste wax on top.
I had to make new baffles so I picked up 2 IKEA APTITLIG bamboo cutting boards $7.99 each. Dimensions are 11" x 17.75" x 5/8" - the website says it's 3/4" but it is not. These are nice because the end grain is vertical not horizontal and they are dead flat, no bowing like some boards with horizontal/flat end grain.
I tuned this to around 55Hz with a 1.5" x 3.65" port. Light stuffing. I'm really happy how they turned out and how they sound. Bass is really nice and not overpowering. The Fountek is great with nice detail and no harshness at all. Paul hit a home-run with these.
I've been enamored with the Altec speakers of old since I was a kid, and worked for several of the last years gathering A-7 components for some type of build. Because of limited space, I needed corner cabinets, and ended up building a couple of striped-mahogany veneered 6.5 cubic foot bass reflex cabs with matching horn cabinets up top.
The components are Altec 511B horns, Altec 802D drivers, Altec 416-8Z woofers, and Beyma CP21F slot super tweeters. The crossover is a two-way second order (12dB/octave) at 800Hz, with the super tweeter rolled in at the 802D rolloff point - 10kHz. A passive CD eq network was incorporated in the horn leg of the crossover.
The speakers are driven by a rebuilt Dynaco PAT4 preamp and two Dynakit Mark IV tube monoblocks.
This is the most gratifying and best-sounding speaker system that I've ever owned, and I'm left smiling every time I crank them up. These are rich.
GeeDeeEmm
Error | Audiokarma Home Audio Stereo Discussion Forums
GeeDeeEmm
Last Pic
GeeDeeEmm
GeeDeeEmm
My speakers, Troels Gravesen's Scanspeak 3W classic.
You can see many more photos and build process in this link:
MY SPEAKER SITE
Great project, for those of you who could be interest in building another. Sound is amazing.
MY SPEAKER SITE
Congratulations dabenza, beautiful build you got there!
Thanks!
- System Pictures & Description
