B1 with Korg Triode
6P1 question:
Dear all,
According to the spec, 6P1 has a common cathode formed by 2 filaments and connected As F1 - F2 (common) - F3
It means that the Korg can’t be used as separate triodes.
If you do have a specimen, please have a look, is there any bridging in between ?
Pin 1-2
Pin 16-17
Such as small metal tab between those pins.
If it does, may be if those links been cut, we may have two separate triodes.
Pascal
The one and only
Joined 2001
Here is the pin diagram, reference triode #1 and #2
1 filament 1
2 filament 1
4 grid 1
7 anode 1
8 ground (not attached to triode circuits)
9 filament center - common to both triodes
10 anode 2
14 grid 2
16 filament 2
17 filament 2
The one pin in common to both triodes attaches to both filaments.
The rest of the pins are named after me.
1 filament 1
2 filament 1
4 grid 1
7 anode 1
10 anode 2
14 grid 2
16 filament 2
17 filament 2
Thanks Mr Pass !
I see better now.
Direct heated triode filament 1&2 = cathode 1&2
Voltage swing
Question
What are the possibilities to increase voltage swing?
Plate choke would be great but with a Rp of 300k Ohm for the korg triode a crazy undertaking.
At the same time there are chokes made by SACTHAILAND with 7400 Henries which makes a -3db point at 10 hz possible
Those are grid chokes but the tiny current of the tube could allow for their use....?
The one and only
Joined 2001
The voltage gain and swing characteristics for the Nutube circuit that I
used were the load-line that I preferred. You can get more or less gain
and more or less distortion by playing with the loading and bias figures,
but it becomes a different animal (one that you might prefer).
If you want to increase the voltage swing I suggest a gain stage after
the Nutube, and while you're at it, you might want to make it inverting,
as that Nutube circuit inverts phase and requires another phase inversion
after it to get the whole thing right. Previously I have just inverted phase
at the speaker when using it.
Hello Mr. Pass,
could I use LSK389 TO71 (available at Trendsetter) transistor instead 2SK370?
Attached files are for THT version.
JP
  • B1-KORG_THT_SCH.pdf
Modifications done.
TKD 2CP601 or ALPS RK09 potentiometer.
Added capacitor multiplier.
I´m working on the part list.
JP
  • DIY-B1-KORG_THT_PBA-BOT.pdf
  • DIY-B1-KORG_THT_PBA-TOP.pdf
  • DIY-B1-KORG_THT_PCB.pdf
