Medium Aleph 3 8ohm@20w.
Thank you guys. right channel one connection loose. I resoldered now fine. Then left channel problem came. Checked and resoldered. When I poweron some small smoke came from left channel board and both channels are playing now.:)
left channel volatge is around 230mv. Right channel is nearly 0mV. so 230mV dont cause any problem. Special Thanks Zen Mod for making me in the right direction.
Thank you guys.
hi ragazzo !
i have transformed my stock Aleph3 in ALeph3 J M
Jfet input , no aleph gain resistor (plain CCS mode), no ouptut resistor ,and 1.8A per device (38W)
i have mesure it yesterday with a friend CLIO and got : 0,01% THD at 1W mostly 2order and less than half 3 order distorsions. start clipping at 12W
for the sound low end seems less controlled than it was before with aleph CCS,
but mids and highs are to die for like a very good Tube SET amp :Pirate:
Tomorrow I will start it.
Hi guy !Yesterday i and my friends turned on the power amp and listened for the first time.
I must say that the first impression was disappointing regarding the dynamics and the extension towards the low range. I hope to be input to the psu that needs a few hours of break-in, otherwise I will have to investigate other possible causes such as the cell L C R on the speaker protector, or genuineness of the 2sj 313.
sounds like too much aleph CCS feedback , try 1K2 or more :)
