6P41s vs 7868
Decrease R4. but why would you want it without the global loop?
I was just trying to make it as low-distortion as possible before applying global NFB. Also, stability concerns. I'd rather not go crazy with little compensation caps, ferrite beads, etc.
As an option, 6AU6 for the first stage, 6AH6 for driver tubes. Nice cheap sleepers. Cheap 7-pin sockets. Also, 6AU6 triode strapped for Concertina.
All good ideas, of course.
Is 6AC7 basically identical in specs to 6AH6? If so, is there a problem using those? I have a bunch of them.
I have plenty of 6AU6, but no 6AH6 in my collection.
Or Soviet 6J4P for the first stage, 6J5P for the rest. Even cheaper, but still nice.
I'd use those if I had them. I do have some 6J51P (similar to EF184). Would those be useful as the LTP driver?
______________________________
PS - I should really build a pair of these RCA 50 watt amps. It seems all the real engineer types love this design.
I've picked a Rowe-Ami recently and I modified it for use in hifi with a couple of 7591 and I enjoyed working on this device.
I bought a second that I want to mount in 6l6 or 6p3S-e and i'm looking for a simple schema, clean and stable for this new amp, but I seek above all to learn and understand.
Ex-Moderator
Joined 2011
I see, since the tube characteristics are different, you may need to change the drive circuit and/or the feedback network, but it should be pretty straight forward. The last schematic that you posted requires another tube to be added, which is probably too much work, so you might as well start with the original Rowe-Ami design and make some changes.
Ex-Moderator
Joined 2011
Basically, you need to change the bias for the 6L6's (from -18.5V to say -26V), which you can do easily by changing the 10k to a pot, so the bias voltage can be adjusted. Depending on the input sensitivity, you need to change the feedback resistor (1.5k) to suit.
In addition, to optimize the load line for the 6L6's, you may want to lower the screen voltage a bit, by disconnecting the screen grids from the B+, and changing the first 1k-1W resistor to say 3.9k-2W coming off the rectifier, and re-connecting the screen grids to the second filter capacitor.
I think I found the winner :)
Monoblocks based on 2x6P41S and 6U10 in UL push-pull output amplifier with Pout more than 15W (~22W at start of clipping!).
applause !!
impedance of the opt please ?
I have another amp that was slaughtered / modified with a very good 6k6 opt and I hope it could do it. the schema of the original that was cut from "stereo mix"
