Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
Trying to sneak in some late night listening (actually early morning) - can't crack up the volume too much. My speakers are Carreras by Paul Carmody. Using the Salas DCG3 preamp, Subbu V3 DAC.
Carrera - undefinition
Sensitivity: 83-84 dB ? Theoretical I suppose.
Min impedance: about 5.2 ohms.
Sorry, you say:
The Carrera sensitivity is 81-82 dB, so not ideal for a 20 watt amplifier, but I am not finding the ALPHA 20W lacking at moderate volumes in any way.
Music with low/very low DR?
Joined 2014
Hugh,
I found an old HiFi Classic review that had impedance curve specs for my Forte speakers and I’m very surprised with huge variation in impedance(even though they are labeled 8ohm):
“The system's minimum impedance was 4 ohms at 150 Hz, which was also the frequency of its maximum output. The impedance rose to a peak of 20 ohms at 65 Hz, then dropped back to 5 ohms at 42 Hz, rising again to about 19 ohms at 20 Hz. It reached an unusually high 130 ohms at 2,200 Hz, then descended to the range of 8 to 12 ohms between 6,000 and 20,000 Hz.”
So, given that the impedance drops below 6ohms for frequency’s that require the most power, I think I will increase my ALPHA20 bias. Thanks.
Vunce
Hi Vunce,
The Alpha20 1.95A can drive about 1-1.5 lower lower ohm compared to 1.45A.
It also depends how much voltage/power you need,
lucky for you your speakers are high sensitivity.
Grts,
Danny
F..k had to goto doctor , took the tests . Fever/flu 38.5C feeling a lot weaker. 3 days of work
Danny can you simulate the amp with a loudspeaker as load ? there the png
I think i goto bed.
Founder of XSA-Labs
Joined 2012
Hugh,
Vunce
Most of that sounds pretty reasonable, it’s the 5ohms at 42Hz that’s a bit problematic, but there is not much content there except for open G on a bass. A lot of the sins of a crossover are absolved with 99dB sensitivity. Basically it doesn’t require much current at all. With higher bias you should hear improved bass authority when listening to bass guitar or more HT type stuff. Most music bass with kick drums is at 55Hz low. The 110ohms at 2kHz means the speaker is acting alimony like a liar of headphones impedance wise. The only cure here is higher voltage, but Alpha 20 can swing +/-15v easily so that will sound good unless you are playing very loud.
Joined 2014
Thanks for the input X.
Danny,
Since the cpu coolers work so well, I will change the appropriate resistors to increase bias to 1.46A and give a listen.
