Mr. Mile,
I want to use it for 56V supplies.
Pl. let me know if the attached, based on your schematic, is ok.
regards
Prasi
For 56V use 30V zener, 24V rele and remove 1uF cap...
Mr. Mile,
Thanks. Here is a compact minimalist version of your softstart with 24V relay that can be placed between switch and trafo.
regards
prasi
Yesterday I tried the F100PSU and no reaction from the relay, just the LED protector is on. I tested at +/- 53v DC.
Where am I wrong?
check and recheck, many of us have done it and it was working unit... by the way, nice work really!
I found where I was wrongcheck and recheck, many of us have done it and it was working unit... by the way, nice work really!
where I needed 220k I mounted 220ohm
Beginner's mistake
![headbash :headbash: :headbash:](https://files.diyaudio.com/forums/images/smilies/headbash.gif)
APEX EX14 simulation results
Hi Mile,
I simulated EX14 in ltspice. I can not get thd below 0.1%. I wonder why that is, any ideas? I will attach the ltspice sim file and the schematic printed page for review.
It is not the models, I use these models in other sims with good success. OPS bias is running at 55mA, driver stage is at 12mA. Just having the red led in the bias generator, would not provide enough OPS bias so I added a small R to get it to where it was reasonable.
Has anyone ever built this amp design?
Thx
Rick
Hi Mile,
Thx
Rick
Beginner's mistake![]()
I always measure every component before laying on the board.
Hi Mile,
Thx
Rick
http://www.diyaudio.com/forums/solid-state/164093-100w-ultimate-fidelity-amplifier-993.html#post5213636
One transformer 48-24-0-24-48 300VA
I finish my transformer. PSU Schematic layout for HX11 please
Hi Mr. Mile...
I wish to make a discrete pre-amp with volume control.
Can you please suggest a good preamp?
My Power amp gain is 27dB.
Signal sources will be less than 1V (500mV t0 700mV)
Thanks and regards,
Sumesh
Go to P30
YouTube
- 100W Ultimate Fidelity Amplifier
