Add virtual center tap to transformer
Is it OK to do this?
PRR
Joined 2003
Yes, within limits, BUT....
The complete current loop flows through the two added resistors. If they are large, your output voltage will drop very badly. If they are small, drop is less, but you have added a LARGE extra load on the transformer, which must be very significantly over-sized.
It will be much better to take the double-voltage from a full-wave bridge and find some way to reduce it.
The solution is to use a current doubler; such a circuit is the dual counterpart of a voltage doubler, and in order to double the current, it also needs to halve the voltage.
Unfortunately, unlike its voltage counterpart, the current doubler cannot content itself with natural rectifiers (diodes): it also needs at least one controlled one.
This switch can be a BJT, SCR or MOSfet.
Nowadays, MOSfets are the natural solution.
Here is a first example:
attachment.php
This circuit is somewhat unbalanced, because one of the capacitors plays a role in the doubler, and also as a reservoir capacitor.
If one objects to it, this can be corrected by adding a supplementary capacitor:
attachment.php
Note that the ripple frequency of the first example is 4*Fin
