Amp Camp Amp - ACA
The ACA needs a power supply that will provide about 80-100w of total power. General rule of thumb for Class A amps is you want a power supply that provides a minimum of 7.5x output power into 8ohm load. ACA = 5w per channel * 2 channels * 7.5 = 75w, then go a bit higher if you can.
Your power supply will provide 24v * 8.8A = 211w of power.
Parallel inputs and outputs ACA
I am wondering if anyone here has built the ACA, and used 2 boards per channel, paralleling the inputs and outputs, for double the current into a 4 ohm load. Naturally, larger heatsinks, and PSU would be required.
I have read over 100 posts regarding the ACA here, and have not come across any discussion regarding this yet, so I am posting this.
I have read Nelsons' Zen amp article,(also have built one successfully), and he states you can parallel inputs and outputs of the Zen stereo amp, turning it into a monoblock, with twice the current, in order to drive 4 ohm speakers.
I have already populated 4, ACA PCB's, (Chinese copies from Ebay). Would have rather bought them here, but they are sold out unfortunatly.
I have a 330VA , 18+18 vac transformer, 60,000uf worth of 35 volt capacitors, and a
chassis with dual 12" by 4.5" heatsinks with 1.5 inch fins, from an old project.
I would be using the amp with a pair of small, 4 ohm, monitor speakers,(Infinity Infinitesimal v.1).
The 2k2 resistors are soldered in to give 1.4 amp bias per board as described here.
With 2 boards per heatsink, 24 vdc supply, 2.8 amps bias, I would be dissapating 67 watts per heatsink, with about 10 watts delivered to the speaker if I calculate correctly.
In my small room, this would hopefully be enough.
Would this be feasible?
Any opinions warmly welcomed.
Thanks,
mg16
Thanks for the answers/explanations, everyone.
I was more concerned with sharing a single source for two amps. I did not know if this particular type of amp needs isolated sources outside of the popular fashion of mono-blocks.
I actually liked the idea of using the bricks which seemed like a tidy solution when all is said and done. This supply, I just happened to already have on hand and just remembered I had it.
The general perspective is to isolate channels from one another so output demands from driving one channel don't impact the other channel. This is probably more appropriate with larger, higher output power amps. Right now, I'm powering my stereo ACA chassis with a single Dell 90w power brick. Works great.
I just got components home from DigiKey for the ACA. I got the 10uF/25v Elna silmic II and to have something to compare with I also got the standard Panasonic 10uF/25v. Then for the project I have a Jensen 10uF/100v alu foil (a "real" capacitor).
I made some some measurements at 10 kHz to check how the 3 capacitors performs. The Elna Silmic II performs worst. The Panasonic a bit better but no match for a real capacitor. Think the data talks for itself.
But people thinks the Silmic "sounds" good?
There will be some "phase error".....
Switches things on and off again
Joined 2000
I'm happy to announce that after an inordinately long gestation period the new Amp Camp Amp kit is finally here.
Amp Camp Amp Parts Kit – diyAudio Store
The parts kit is now more affordable ($129), and the new stereo chassis is the same price as before ($149). The parts kit ships from the USA, and the chassis direct from Hifi2000 in Italy. There will be much more posted about this over the coming days, including a new build guide from 6L6 and some special tips and tricks for advanced users.
The old PCBs (1.0 and 1.0b) won't fit into the new (Mini Dissipante based) chassis, as the MOSFETs would hit the heatsink brackets. To get around that, we came up with a new 2U UMS specification (yet to be published), Nelson redesigned the circuit board (V1.1) to suit that and now we have a very good looking 2U UMS format for small amplifier projects. If you have one of the old ACA boards, it may still be possible to use the new chassis using jumper cables to the MOSFETs (not yet tested, don't shoot me if I'm wrong!), but for now please consider the old boards and new chassis relatively incompatible. We'll have the new 1.1 boards available for individual sale in a month or so.
More information to come...
I am also in! ....and got my order confirmed. Good I was online when the message arrived. The cabinets will be shipped directly from Italy as I am in Europe. I ordered two cabinets as I build them as mono blocks. I need the extra space for my big input and output capacitors.......two sets of speaker terminals will still be used pr. cabinet as this gives an easy way to bi-wire......and then a big cabinet for the PSU's.
It looks good. Damping factor raised from 3 to 10 and a bit lower gain caused by more NFB I guess.
My DAC has more than 2V p-p output so should still be able to use a passive pre-amp. Think it is good to have as much signal output from the pre-stage as possible to get low S/N ratio. I may switch from a 10k stepped attenuator to a 5k. Will depend on how it works......
