200W MOSFET CFA amp
Got them 675EE0C9-725B-40A9-B7C2-1B1C9515D30D.jpg nice!
David
Case for Damir 100W CFA Amplifier
This is Aluminium 5mm case for 3 channel Damir 100W CFA Amplifier.
Aluminium plate cut by Water-Jet CNC machine. On Both sides will be mounted big heatinks 300x210x40mm. On front panel rectangular hole is for big analog VU-meter.
What kind of meter? A actual meter with a mechanical hand or a LCD Display one that would be able to do more than pretend to be a mechanical display.
Your case is outstanding, What is the TOTAL cost with the cost of the Aluminum? Excellent choice of materials and design. Now to hear some Singing.
Krisfr
when I said analog VU meter it means analog instrument not digital. Like in this photo. I have also idea to put LCD display in case that I will not be satisfied with analog.
Total cost Alu material + water cut is 150 Eur for 2 cases. Case is big and robust.
Krisfr
Mario how are you going to connect one VU meter when you have 3 separate amps in one chassis?
Krisfr
Look at this if you like to see what can be done. Again very beautiful work and soon to be listening. Thanks
YouTube
You can set it as a peak meter.
attached, the idea.
And, if you are afraid of a non linear little load at your loudspeaker's output:
R1&R2 has to be set at the limit of conduction (the needle of the vu meter just moving at the limit you can see ;-)
The 4.7µF fasten the measurement of the peaks, while the 22µ slow the decrease .
Tournesol
For what kind instrument is suitable this schematic. I have 100 uA meter. Idea was to buy soldered modul from ebay.
It will be OK. You can adjust the bridge values that load the amps outputs to adjust the sensitivities. First with a sin at full amp power to get, by example +3dB on continuous mode. On each amp, because your meter will always show the highest level of the three.
Then, with the amp output at -3dB from full power, adjust, if needed the value of the 4.7µ in order the meter do not goes over +1dB when you put the sin signal from off to on.
A pure vu meter will never indicate something useful with musical transients. And what you want is to be sure you dont bring any amp to clip, right ?
2n2222 will be perfect for transistors.
Some time ago I had the first auditions with the Dado GW MK3 preamp which I was very surprised at, how well it sounded.
Last night I did an audition with amp Dado 200 MOSFET amp and GW MK3 preamp.
What can I say ... It's so good that I stayed until late at night to listen.
It impresses you all - crystalline voices, very beautiful and articulated bass (even at low volume), very silent. Having a lower voltage (+ _45V) and a generous heatsinks, I set a 300mA bias on the MOSFET. The sound was special. I will come back with pictures later, this amp deserves to be put in the beautiful case.
A question :)
Would it be a win if I put 2SJ201 / 2SK1530 (instead of IRFP240 / 9240)?
If so, what changes should I make?
Thank you.
