Class D Amp Photo Gallery
Looks like IR20957 and postfilter FB. Is it Post filter only?
I'm working on a design with IR2092 with a combination of post and pre-filter FB, where the OTA amp in the input is used as comparator, so compared to IR20957, omitting one component.
Seems you are using a buck converter for the gate drive supply. Which one? Haven't been monitoring the development in this area, but maybe I should, the problem has been that the input voltage has been limited to around 60V, where 100V would be ideal for the IR gate ICs to batch their max supply voltage.
What is MDR input for?
Nice PCB :) ... 5 x 10 cm? .... this is what I'm trying to limit myself to ;)
Disabled Account
Joined 2005
My UcD Fulbridge for PA
Supply +/- 90Vdc. Tested live to drive 2x18" vc 5" and the speakers are on peak already
Small Class-D Plateamp
Finished my small plate amp for my mini sub
( Reckhorn Mini-Sub )
Amp based on IRS2092 but with a mix of post and pre-filter feedback.
Running 200 W i 4 ohm, using a Connec Electronic 240R SMPS with +-40Vdc.
