A nice marriage of old style and modern tech. Play the video and see what they do with the horn/speaker!
Kozmophone - a classic reimagined! by Arcateliers —Kickstarter
Jab
Jab
Hi John,
Pretty much every time I test an expensive audiophile approved part, I can find the same or better in normal industrial parts. That is both measuring different parameters and listening to the darned things.
It should be noted that the normal parts are considerably smaller than the special parts are. When I strip the silly parts out and install the (usually) better parts, a couple things tend to happen. Firstly the chassis looks neater as these parts actually fit. This may be more important than you think! Secondly, the customer tends to fall in love with their "de-audiophilized" device.
Cleaning up after someone who installs these large parts is frustrating. They often destroy plated through holes - and that leads to either a fault or intermittent operation. The other issue is getting rid of literal gobs of silicone or hot glue so you can work on the PCB. I like the special neat guys who thoughtfully drill out the plated through holes. This is especially nice when a trace has a hole in it as it travels by. The hole typically interrupts these traces completely. Lots of repair work. Occasionally I get a unit that is too damaged to be made reliable again at sane money. Those I have to write-off.
Internet modders cause a ton of damage without knowing it. I wish these folks would stick to something they have a good understanding of (really know, not think they know).
-Chris
Examples?
I can understand what you're saying. But at the same time I have never found a replacement for expensive film caps in the signal path. There are good sounding smaller, cheaper, caps, but never as good as offerings from audiophile/speakercrossover companies. And while I don't use them typically, teflons do measure superior.
Aside from that I am not super familiar with what products are so big, and have superior smaller replacements. I like Dale resistors, which measure the best for under $12-15/ea (they're less than $1).
Well Dale resistors are an industrial part so not sure what you mean there...
They are considered an audiophile grade, too. They get a variety of names from manufacturers. "Mil-Spec" "Ultra precision" blah blah.
Jab
That looks fun! I wonder how it will perform...
How would one achieve "audiophile grade" certification?
Wrap it in gold font and charge a lot.How would one achieve "audiophile grade" certification?
Ask the manufacturerHow would one achieve "audiophile grade" certification?
RS Series Thin Film Chip Resistors - Susumu | Mouser Canada
or look at their datasheet to support their claims,
https://ca.mouser.com/ds/2/392/n_catalog_partition23_en-1116117.pdf
look pretty good to me with the limited specs
Improved low noise thin film character even further
Choice among the same resistance/size according to the user's sound preference
Precision resistance tolerance: ±0.1%, very small TCR: ±25ppm/℃
Limited selection from Mouser, for a precision part
for a 0805 pretty expensive
Do you think Vishay/Dale makes one similar to above at the same cost.
This millennial thinks it's ******* turd that won't sell at garages sales in a few years.
You have to admit it's a facet of the current "vinyl revival" that proves it is sort of empty. I still have 100's of my grown daughter's Beanie Babies if anyone wants them.
Ed Simon MEASURED the DALE resistors and found them superior to many other resistor brands. Dale is the new 'default' standard audio resistor in today's audio designs. They are reasonably priced too!
John Curl & Nelson Pass are not bad endorsements for a resistor. (Whoever designs for Lamm uses them exclusively too)
I have always used Vishay Dale resistors both for instrumentation and audio. Just because I was able to make a choice of resistors with good specs and behavior from this company. But never considered them as "audiophile grade", in fact I do not know yet which specs are covered by this definition. I have read both nonsense and rational, covered under audiophile grade term.
Indiscriminate use of Dale r's (we are talking about the RN series right?) leads to a somewhat dead sounding circuit. I know. I was stung by a review long ago on Audiocircle.
Doesn't bother the CAT, MRI, or PET scanners I guess audio is more important than people's lives.
It isDoesn't bother the CAT, MRI, or PET scanners I guess audio is more important than people's lives.
They are lower noise than about any other resistors, and on top of that it's mostly 2nd HD. PRP as another example leans towards 3rd HD but is similar overall in performance.
- Member Areas
- The Lounge
