Given high end audio could do much much much much much worse than the high end data acquisition/instrumentation space, who cannot get enough performance (see: the entire reason we even have the ad797 today).
Most any of the line-level audio IC's released today were originally for instrumentation.
My problem is with designers using audio qualified linear op amps and excessively loading them for whatever reason. For example, a 300 ohm load on a 600ohm spec'd device. How about driving a headphone with a 5534? Apparently the sine wave analysis does not necessarily show much wrong, but what about a transient test?
...How about driving a headphone with a 5534?...
if you cut the age of the op amp design by an order of magnitude:
• High-Fidelity Sound Quality
• Ultralow Noise: 2.8 nV/√Hz at 1 kHz
• Ultralow Total Harmonic Distortion + Noise:
–119 dB THD+N (142 mW/Ch into 32 Ω/Ch)
• Wide Gain Bandwidth Product:
32 MHz (G = +1000)
• High Slew Rate: 10 V/μs
• High Capacitive-Load Drive Capability: > 600 pF
• High Open-Loop Gain: 136 dB (600-Ω Load)
• Low Quiescent Current: 2.6 mA per Channel
• Low-Power Shutdown Mode With Reduced Pop
and Click Noise: 5 μA per Channel
• Short-Circuit Protection
• Wide Supply Range: ±2 V to ±18 V
• Available in small VSON-10 μPackage
OPA1622 ?
It is a product most probably targeted at mobile devices (phones or what not).
We built one or two.
Probably OK compared to other opamp headamps.
But no comparison to our other discrete designs.
It has been sitting in my drawer for the last 9 months or so.
http://www.diyaudio.com/forums/vendor-s-bazaar/283672-audio-op-amp-opa1622-25.html#post4747938
http://www.diyaudio.com/forums/vendor-s-bazaar/283672-audio-op-amp-opa1622-27.html#post4789925
http://www.diyaudio.com/forums/vendor-s-bazaar/283672-audio-op-amp-opa1622-30.html#post4953256
Patrick
So how is an incompetent designer related to the op amp audio performance?
Joined 2014
I give a lot more leverage for what is in essence a musical instrument. Overload is less characterized so understandably a bit more of a shotgun approach.
Yes, but a Luthier understands how to work with the materials at his disposal to get the desired result. A pedal maker to the outside world seems to be several orders of magnitude less 'craftful' . I suspect the punter needs to know about magic vintage leak-a-lot caps and carbon resistors as well.
