At what freq. does your Paradise cut off with these changes?I had also used half the total mF at the emitters and deleted their bypasses. For earlier subsonic roll-off.
Link takes me to the last page of the thread , I found your values in the manual: 12nF, 34.7nF, 9.1k, 67.8k , are these correct?It was measuring 62dB on mine (Rev2 PCB). My RIAA values twist was http://www.diyaudio.com/forums/analogue-source/218625-paradise-builders-199.html#post3438188
Looks like you're cutting bit of LF and HF , I listened last weekend to Paradise and it seems to over emphasise a bit HF in my system your values might be a way to go .
Link works on me, so here is my old post's text:
"Miib tuning has a bit more treble and bass. +0.4db HF +0.2dB LF in my build by measurement. Add 1nF to the treble caps C2a, C2b and parallel 820k-1Meg to R9a R9b. Matter of tolerances. You are looking for 67.8k net. That way it goes near neutral so you can have an alternative listening session. Its a matter of taste and system integration mainly."
LookAt what freq. does your Paradise cut off with these changes?
Salas post4095 link takes me to post3691Link takes me to the last page of the thread ,..............
Must be Chrome playing tricks on me , checked with Microsoft Edge and it takes me to the said post , thanksSalas post4095 link takes me to post3691
Thank youTakes me to correct #1982
Until Jason will take the forum to a new platform there are various buggy things going on with browsers it seems. I have copied the original post's text four posts above anyway.
That makes for 33n3 12n 9k1 67k8
I' thinking about something like , mains ground going to the chassis of PSU unit (star point) , both DC supplies ( 2 transformer build) going to the star point via 10R resistor, both RIAA chassis connected to the star via 10R , tonearm ground connected to one of the RIAA chassis via 10R
Most of the time I'm using something like a 1n4007
But this S2K100-5000 or 1N5404RLG would be better (or most DO201's 400V or higher max surge current 100A or higher will fit the job).
At worst the diode should survive a mains short over the diode (to be absolutely safe).
Finally getting around to building up my Paradise boards and have a quick question about matching.
I've done a first sift on a Peak DCA 75 (the one that does curves) and I'd now like a good match on the input transistors.
Each of these, I understand, operates at around 3.5mV, but on the tester you need to specify the Vce as well. Any ideas as to what to input here? It's a bit of an issue as hfe is pretty flat with the npn's as Vce rises, but hfe with the pnp's rises quite a bit with Vce.
Thanks in advance.
Thanks in advance.
OPA2140
Has anyone used the OPA2140? Is it as good as the OPA627?
If not as good, should I use OPA627AP or BP?
OPA2140AID | Texas Instruments OPA2140AID, Dual JFET Op Amp, RRO, 11MHz, 4.5 → 36 V, 8-Pin SOIC | Texas Instruments
We have being talking about a low cost alternative to the OPA627 as a servo.
There is a new precission Fet Opamp from BB :
http://www.ti.com/lit/ds/symlink/opa2140.pdf
This one really has great DC specs, very low distortion, low noise and a wide PSU voltage range.
Needs a DIL adapter though to be used in the Paradise.
I have not tried it so far. Even for me as an opamp neard it is hard to catch up whats new and usefull.
- Analogue Source
- Paradise Builders
