MOX builder’s thread
Hi Bricolo,
1 pole Butterworth use Q=0.7071
2 pole Butterworth use Q=0.7071
3 pole Butterworth use Q=1 & Q=0.7071
4 pole Butterworth use Q=1.3066 & Q=0.5412
L-R2 use cascade Q=0.7071 ( 2*B1 )
L-R4 use cascade Q=0.7071 ( 2*B2 )
L-R6 use cascade Q=1 & Q=0.7071 ( 2*B3 )
L-R8 use cascade Q=1.3066 & Q=0.5412 ( 2*B4 )
As you said, all these filters are set at the same Xover frequency.
Do you need the gain settings to achieve these Q values?
Have you read LeCleach on xover modification yet?http://freerider.dyndns.org/anlage/LeCleach2.zip Then you have to change frequencies.
Can this mod be modelled on Moxlite?
Has anyone listened to this mod yet?
It's not very usefull to set up an audio filter, since everything is already pre-calculated and many tables are available.
But if you want to have a deeper look at the theory, and where those tables come from, you can read those pages:
Do you know what a s-plane is? Basicly, it's a map where your poles and zeros are placed, according to theyr Real and Imaginary part.
This chapter seems good
http://www.phys.ualberta.ca/~gingrich/phys395/notes/node38.html#SECTION00400000000000000000
And for Butterworth filters:
http://www.microindustrie.com/dsp/b-dis.htm
Tables are always normalized to a frequency, when using tables to design a filter, you also should look up frequency scaling as this is needed to calculate the parameters in the non normalized filter.
Frequency scaling "moves" the corner-freq from the normalized frequency to where you want your filter to have it's cornerfrequency.
I hope I make sence :xeye:
\Jens
Butterworth 4 pole
Hi all,
I have attached an excel spreadsheet to calculate the caps & resistors for a 4 pole low pass filter.
It uses 2 cascaded unity gain stages (moxlite) with staggered Qs of .54 & 1.3 to achieve a total q=0.7071 for Butterworth roll off.
Each stage could be used for odd values of Q if Mox shows the need to tailor the Xover to your speakers.
  • unitygain4polefilter.zip
Joined 2000
Was able to get two dual opamps made and working. Sounds nice. Its like taking a restrictor off.
The National Semi opamps were good, but this better.
I'm going to turn those web pages into a PDF and post a couple a pics. Someone will eventually need to reference the info. I think there are boards still floating around out there.
Thanks,
Vince
Joined 2000
MOX II- Populated Boards
Here is some info on assembly of the MOX II discrete opamp.
  • MOX II Discrete Opamp Assemble Guide.pdf
