Tube-I-zator Professional PCB
I am unable to source the heater switch and intend to solder the bridge. If i am using 6n2p, is this the correct way to solder? See attached picture.
Joined 2009
Hello Oliver.
BZX55/C12 SUBSTITUE
Can i use other alternative 12 V zener substitute such as 1N4742A ZENER DIODE 1W 12V ?
Or this one which is cheaper ?
Is the zener tolerance critical ?
1N5242B - ZENER DIODE, 500mW, 12V, DO-35 from Multicomp with 5 % tolerance
i must ask Salas, because it is his circuit. ;)
Stay tuned...
Joined 2009
Hello everyone,
Can I use 12bz7 tube in tube I-zator in 3.1?
(so I did not change the original body parts)
Thanks.
if you want to try the 12BZ7, go ahead.
The double heater current (see attached data) is no problem for the heater circuit. Maybe you will need a bigger heatsink for the LD1085. ;)
Best regards and happy Easter,
Oliver
  • 12bz7_sylvania.pdf
  • 12AX7.pdf
Joined 2008
Hello Oliver,
I'm finally (after 3 years!) getting around to building my Tube-i-zators, and I want to use them with a voltage-out DAC chip in a Cambridge Audio DVD99. I'll add the cap, but what value should I use for RI/V? Lukas' instructions suggest 250K, but his circuit is a little different than yours. I'll be using 6H6P. Thanks David
