Has anyone used the sanwu bluetooth tpa3118 2x30?
TPA3118 Bluetooth digital amplifier 2X30W stereo modified Bluetooth speakers
I use that for my garage amp. Being the garage, I'm not looking for the best; just cheap, easy and works. This board meets those criteria. I find the speaking woman more amusing than annoying. But then again, very low expectations in the garage. I never noticed any hiss on mine.
Congratulations Doctormord ! I see you did design a better version. Even smaller than the competitor.
Makes me wonder what the cost is. The blue Sanwu are quite hard to beat in that aspect.
About $40 in BOM cost, also due to the use of softterm/flex ceramic caps, 0.5% resistors and these connectors. You may strip the costs down if using X5R standard MLCC, 5% resistors and cheaper connectors. I suspect the chinese massproduction could bringt the costs down below $10 with parts from "local" suppliers.
But costs weren't mainly in focus while planing this amplifier. There also is. o snake-oil involved.
The blue sanwu boards are a bargain , but one should change for better inductors if used with 4R speakers at higher levels.
Is Sanwu still the bargain to choose
TPA3118 PBTL mono digital amplifier board 1X60W 12V 24V POWER AMP-in Earphone Accessories from Consumer Electronics on Aliexpress.com | Alibaba Group
or is the even cheaper version just as good
1pcs SAMIORE ROBOT TPA3118 PBTL mono digital amplifier board 1X60W 12V 24V POWER AMP-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
I suspect, they're all made from the same..
Yes, actually I see that on the cheap one, it says Sanwu in the discription. It's seen in the background - behind the drawing of the module.
I ordered the higher priced version from Ali with Sanwu in the picture and not only did not receive Sanwu branded, but they appeared to be made by different manufacturer or at different times, the inductors did not look the same, print was fuzzier on one than the other, and they were different shades of blue.
Vendors reply: "We don't always send out what is in the picture."
The advice given here is to just order the cheapest, which I did for a second set and I am happy, they at least look the same to each other and appear to have identical devices to the others I received.
I subsequently emailed several vendors on eBay regarding whether they send out the branded one, most did not reply, the ones that did would not commit to sending out what they pictured, so there you have it. Just order the cheapest.
HomePage - Sanwu Lasers has some Sanwu branded boards (not the plain TPA3118 at the moment, though) and everything I have gotten from there has been branded and they do look to be a bit better cosmetically (sharper printing, uniform color, etc).
Thanks - are there any types that are no-go? Regulated vs unregulated etc
I have tried to find out information, but it seems very fragmented. Most just use the cheapest (free - or whatever thay have lying around) solution.
I actually think I have a meanwell 24 volt/5A lying around
Regarding the MeanWell supplies, avoid/beware of any knock-offs/lookalikes/copies available from Ebay/Aliexpress/TaoBao/Whatsoever.
I got myself some (knockoffs) to see how good/bad they're made. While working in first place they lack in creeping distance, isolation and part quality. Some came with recycled high-voltage parts like bulk caps, XY-caps and even the underlying isolation material where resused LCD-backlight-foils which were to thin.
You pretty much get even less than you pay for. The underlying smps concept of the MeanWell supplies isn't any complicated rocked-science but they're made in a reasonable build quality, safety tested and certified for not much as x2 the price of a knockoff.
Don't know either - but it seems odd to pay 200$ for some off the shelf meanwell 2,5 ampere SMPS units. I have pro made modules/finished amps with SMPS cheaper than that. IMG Stageline Pascal S-Pro2 and Audiopower MDA400S
Thanks for the suggestions. I guess I will make some different PSU's and try
Where do you but $200 MW supplies? They are $10-40, depening on power and providing excellent value for the price. But yeah, a crappy amp won't (most likely) getting any better with a good supply.
The main reason to me for getting a brand name like MW is safety and tested performance.
- Class D
- Cheap TPA3118D2 boards, modding them and everything that comes with it
