50w Single-Ended BAF2015 Schade Enabled
Why did you change your mind?
I recently heard the pre65 amps at a DIY event in England driving a pair of open baffles. They sounded fine though it was difficult to tell much given the acoustics of a large reception sized room with unforgiving speaker placement. The heat sinks measure 13" x 8" x 3" and barely get warm when the fan is running.
There are photos at Ray's Retirement: Owston - a visit to DIY Audio Land
The amp sounded good enough to persuade me to build a pair when I get back to the US. I have enough heat sinks and I am going to go the SMPS route. I had wondered about doing a 48 volt version but after discussion with pre65 I will go with 60 volts. Hopefully my Mouser order will be waiting for me at home and I will get them done before September when I head off to Oz.
ray
Shade 50 in action :note:
Interesting blog thank you :cheerful:
ps: i like it that photography's
Here is a scaled down version of the 50w Schade circuit. I built it into a pair of ACA chassis using the ACA boards and a Semisouth R100 for Q1. It runs about 1.2A bias at 24V. I don't have a distortion analyzer so I cant provide those numbers, but it does sound nice.
The ACA circuit and board must be modified by omitting Q4, R9, R12, and R15. Jumpers must be installed across R11 and from In to Ground. R14 must be replaced by the two feedback resistors standing vertically off the board.
Pass DIY Apprentice
Joined 2001
My intention was to do some boards, test them, and give them to the guys at diyAudio to use as they see fit. But, it appears that for the general DIYer, an input buffer is going to be practically mandatory and I have yet to go back and add a buffer to my boards. This is still on my to-do list, but presently my day job (we acquired another company so now I have two day jobs) is limiting my bandwidth. :)
It will likely be later this Fall before I get to it, and I wouldn't be the least bit offended if someone beats me to it. I'm sorry, I haven't been as productive this year as I would like. :)
Take it you didn't use the opto-coupler?
Did you have to change R1 & 3?
Nope, no opto-coupler. The ACA circuit does the same basic thing though.
Didn't have to change any of R1-4. In fact I built it with the standard ACA values there first. Sounded fine. I only changed them to bump up the bias a bit without resorting to R15 and to tap the actual midpoint.
The circuit is quite flexible and will work nicely with many options for Q1 that can plug right in. IRFP240 included. For those who want more power the ACA board should bolt right into the larger deluxe chassis in the store. That would allow much more voltage and bias.
Busy modern life !
All major time at work or two jobs :D
Find moments for family and friends and
if miracle happen for diyAudio hobby as well.
Buffered Schade50W version pcb's boards is a genious great idea !
Thanks Michael for sharing of your precious time on the forum with us.
