Cheap TPA3118D2 boards, modding them and everything that comes with it
1.2MHz 1SPW 26dB with speakers that form slightly overdamped filter with 15uH/0.47uF, so outputfilter ringing precaution for 1SPW operation seems taken care off imo. Selecting energy savings modulation with 1200kHz max switching speed seems a little irrational, but probably makes it sound warmer.
Bass reduction mmmmm
Try this board, you wont have to do any mods.
m.ebay.com/itm/XH-M189-TPA3116D2-2x50W-Digital-Power-Amplifier-Board-Class-Stereo-Audio-TE743-/262975067368?hash=item3d3a8914e8:g:qUUAAOSwlndZETDw&_trkparms=pageci%3Ab6d315ff-6aa3-11e7-bc51-74dbd1803c05%7Cparentrq%3A4eaf64a315d0aa1182997857fffb7b79%7Ciid%3A3
Sent from my ASUS_Z00AD using Tapatalk
This board looks like a clone of one of mine. But mine has a number of markings and label on the bottom side of the PCB. The one I have sounded pretty good without adding anything. For someone who wants to check out these inexpensive amps, not a bad choice.
Hi,I would like to ask for help with some amplifier issues that i'm experiencing. So I 've bought two of tpa3118 mono boards dirt cheap and I'm getting some annoying white noise /hiss issues . As showed in previous posts I removed 100k resistor in order to lower the gain thus reduce the hiss, but such reduction did't occur in significant maner, the hiss is still loud.
Here are pics of testing set up ,I'm using 16,8v (18650 with bms) battery pack.
Connecting signal source doesn't bring any improvement on hisss situation, just saying though.
Thanks for the help , shorting out input did the trick .
One more question is there a way to get rid of power surge "pop" on start up ?
I'm running those borards in this box , I'd say that they sound decent enough for the price .
You fixed the noise issue your setup had ?
Shorting the + input only shows what is ampboards own noise contribution with both +/- inputs grounded. It may help eliminating potential causes for the noise, but fixes nothing.
