Photo Gallery
Done!
High end audio amplifier. 42W per channel maximal power. Single ended (of course class A: SE amp can't work in any other class!).
GK-71 Soviet military output tubes. 12HL7 driver tubes (designed for color TVs frame grid, very linear pentodes). Voltages for G1, G2, G3, and driver are stabilized by MOSFET voltage regulators. DC for filament is derived by 150W SMPS, that's why the amp is so small. Proprietary schematic design, both stages pentode, with nested feedback loops. The result is, the sound is cleaner than from triodes, and output power is more than can be get from a pentode with no FB. Soft clipping, despite of the myth that feedbacks ruin the sound. 20 Hz - 50 KHz bandwidth before visible on oscillioscope roll-off.
I never heard a better amp!
PS: I had to convert pictures to 800x600: now the forum does not accept 2MB files.
Administrator
Joined 2004
No mosfets.. Fixed bias, not filament bias - I'm not a fan at high voltages.
There are 25V LT1083 based pre-regulators in the power supply chassis which each dissipate around 15W, and each Coleman regulator also dissipates 15W.
Each tube dissipates a total of 180W worst case, and each amplifier consumes about 235W. All linear, no switchers.
The amps are monoblocks with outboard supplies, and heat up my listening room rather significantly which is fine for about 9 months of the year.
