900W H-class PA Amp with Limiter
  • forum.vegalab.ru  V.2013 storey PRO-amplifier in the class H pg 11 3 ?????.GIF
Exactly,
But tell the procedure to the guys who don't even have an oscilloscope, all they have is a multimeter.
A simple solution:
Feed a 50-100hz sine at input and measure the voltage at output with your DMM and see its more than Low rail voltage and touching the high rail voltage or near to it. Its just an approximation of its working.
Thanks kanwar very useful information right there .:cheers:
  • datasheet AD8002.pdf
  • datasheet tl071,72,74.pdf
hi Guys,sir apex, working on this apex h900 tef,,,amp section is ok now,,,but have a problem in dc protect even applied with 3vdc in output...over heat protect and fan speed is working...did anyone encounter this problem regarding on the dc protect ckt??can i ask for some test point on this protection circuit that is working already?Thank you!!Regards
