Crossover for two way with Vifa D25 and Dayton DC200
Steve is using Boxsim, a free speaker simulation program from Visaton: Downloads
And if he would use the software correctly, he would see how bad his crossover proposal actually is. But he prefers to do fictional simulations using wrong drivers. I have given up all hope.
Attached is a zip file that contains all driver data files and two Boxsim projects (crossover System7 and Dissi).
I see that 2kHz resonance you mentioned.
Is the woofer crossover in your schematic just a notch as Steve said? Would it not be beneficial to add a lowpass too to get rid of the higher frequencies from the woofer, I can see from the graph there are some there.
I have to agree with Dissi, that the Dayton DC200-8 is the 8" woofer from hell, at least in a two way. :eek:
TBH, it is worse than I thought. I usually assume on well-behaved woofers, and that is what I buy, below. This Dayton reminds me of those awful Scanspeak 6" sliced cone woofers.
H1471-08 CA22RNY
But I always enjoy tangling with Dissi. I think my revised ideas here are excellent. Glorious amplifier-friendly impedance and better rolloff on the bass. :D
TBH, I have no idea what is going on with phase aka polarity and time-alignment, but something ought to work. For sure, the tweeter is getting worked hard.
What I don't like is those old 10" bass AR 38S speakers. Terrible problems on a simple notch.
Raccoon1400, it is time for a review. Your original Energy ESM-2 speaker was a failrly traditional 8" polycone bass plus 1" tweeter design.
Here's the spec for the speaker:
Freq. Response: 40 Hz - 22 kHz
Tweeter: 1" Ferro fluid cooled
Woofer: 8" Polypropylene cone with rubber surround.
Crossover: 2.0 kHz phase corrected
Efficiency: 86 dB SPL/W/M
Impedance: 8 Ohm nominal
Recommended Amp Power: 12 to 100 W RMS
Size: 23 3/8" H x 10 1/2" W x 10 1/2" D
Weight: 24 lbs ea.
You have inherited a botched repair project here. IMO, you are throwing good money after bad. You might get away with a well-behaved 8" midbass paper cone here, but the Dayton DC200-8 is actually a pure bass unit. A rotten choice as replacement. Which is where Dissi and I concur.
All I can say, is don't get your hopes up. It'll never be a good speaker. :rolleyes:
We'll see I guess. I'm not expecting the world.
