6V6 line preamp
diyAudio Chief Moderator
Joined 2002
Can I use the attached power supply circuit plus regulator with 2 x 6V6 tubes for the 6V6 linestage??
How can I adjust the power supply from 300v to 340v??
It is a tubed regulator already. There is the 200K VR on quick look but I don't know the well working voltage drop margins. Anyway, 300V is still useful for this preamp. About its max well regulating Vout and its max pass current you should verify with its designer. This preamp would be happy with 60mA available for two channels.
Joined 2011
O boy. It should regulate good enough but that is one beast of stealing power. The 3 k alone in the series reg burns some 15ish Watt. Interesting grounded grid high mu to inverting low mu high current section though.
And yes the 200 k VR adjusting the 6V6 grids as shunts via 12ax7b section but that is only designed as a fine tuning.
Hi ...
I have already finished the wiring, I measure 440VDC with bleeder resistor 220k, I will put 13.5k as load and I measure again the output Vdc from caps before fit to SHV2 regs.
Joined 2002
Don't allow much dissipation across Q1. It is not a low Θjc device. It would heat up fast enough even if you had boosted its sink mass. About 1.5-2W max allowance will be prudent. In other words if the raw DC is more than 370V for 60mA draw, burn some extra on a resistor somewhere in the raw section.
Joined 2002
I don't know your chokes RDC and the expected drop across them but use a test load for raw DC representative of the reg's CCS mA setting. 10-20V drop across the reg is enough, 20-30V is not too taxing given the CCS draw is enough for such a preamp.
Here some measurments as 6V6 buffer
Τrafo 640 CT , 5V/3A, 10V/2A, 10V/2A
5AR4 SOVTEK
+330V, Heaters 6,12V, 6,21V
PSU 16uf+1K16uf to 1) 100uf+10H+100uf
2) 100uf+10H+100uf
1)probe X10 +330V
2)probe magnified X1 +330V
3)Output
4)Output
5)Heater
6)Heater
