Simplistic NJFET RIAA
And do not forget the impedance of the phonestage( 47k for MMstage) at the output.
In all the papers they talk about signal generator impedance but they forget the impedance at the output.:cool:
question: wouldn't it produce higher precision to just create a RIAA with R5 trimmable so it can be calibrated for the specific generator for max accuracy and then buffer out the output of the RIAA with precision OP-AMP in Buffer configuration so that you take out the uncertainty of the input stage?
You can't have a precision number on input stage impedance and also it can fluctuate over the measured band. With a buffer you have much more precise results IMO and you can swap any phono stage without worrying about input impedance.
here´s the inverse RIAA I made 10 years ago.
One can switch between 0R, 50R 550R and 600R of source impedance, as well as MM level (-40dB/600R) and MC level (-60dB/60R).
Dimensioning after D. Colins Article "Tweaking the Passive Inverse RIAA Network" in AudioXpress 2007.
Parts are standard metal film and silvermica (stable, low tolerance, quite affordable from Reichelt.de) connected in series-parallel to reduce tolerance.
Diagrams show the diversion from ideal response (red) to real(blue).
A nice little gem that proved its useabilty many times. ;)
jauu
Calvin
Measured my turntable today, cables hooked up but without cartridge. The total capacitance 140pf left channel and almost the same in the right channel. Inside my riaa i have 150pf loading at C2Y. So the total is around 290-300pf loading.
My cartridge Nagaoka mp-100 want's less than 150pf according specs.
Can i try without anything at C2Y or is it better to try something like 10pf to come close to 150pf's loading? The riaa and the sound is very good but i like to try if i'm gaining something to come close to the spec of the cart.
diyAudio Chief Moderator
Joined 2002
C2Y is shaping the HF portion of the RIAA curve, its not an input loading element. Less value gives bit more HF, more value gives bit less HF.
Joined 2002
You understood right. And yes, the input stage itself will add pF. Its cascoded and in MM mode that you use it has enough source pin degeneration resistor value also (local feedback), so its moderate in doing that, but less cable will still be better. There are also some coaxial cables to choose that have less pF/m than others.
Did you box the build by now?
I´m afraid no:eek:, spent all my money buying vinyls:) Have to prioritize to box it soon.
That is my build. Cases are from Modushop in Italy[same as store cases]
The larger cases are 2U high and are 330mmW by 230mmD whist the psu is 124mmWx230mmD.
https://www.modushop.biz/site/index.php?route=product/category&path=67_194_119
Depending where you are it might be easier to buy from the store.
Thank you for the information!
Do you consider everything a good fit? Are you happy with the internal size for everything? If I could get a shot of psu and boards inside that would be very helpful as well if it is convenient.
Sent from my iPhone using Tapatalk
Something that was rolling around in my head regarding tolerances and matching of the signal caps:
I've noticed a lot of talk about capacitor brands and their attributes, but what in general should we be shooting for in terms of matching between channels and tolerance to the specified value in the SFS BOM? Seems this is discussed far less than the differences between mundorf and obligatto, for instance.
I could very well be wrong as this is a general assumption but it would seem to me that when many are swapping caps to determine their merits some of the changes in sound signature they are describing could be that of the value difference in caps as much as different film cap construction materials?
For example, would precisely matched generic film caps at 2.2uf each channel be a better strategy than silver PIO caps that are 5% off each channel?
What is an acceptable versus non acceptable tolerance and what effect does this have on the circuit and sound? Is there a general guideline to follow?
6L6
Moderator
Joined 2010
Do you want accuracy or color? Audiophile caps add color. Many of said colors are very beautiful, hence the popularity. This is not, in any way, a bad thing.
Well matched polypropylene caps will get you accurate RIAA and also great sound. This too, is not in any way a bad thing.
