Amp Camp Amp - ACA
Hi guys
Have a question around setting bias of this amp. Does it make any difference if we attach a load to the output? Someone told me I needed to but never read it here anywhere.....
4 Channels on my 420mm x 275mm heatsink runs way too hot, can't touch it!!! Just wanted to make sure my bias setting method was correct, no load and 10v on the Q1 drain.
Is it correct that these run at about 26 watts load or no load? So that means my setup would be around 100 watts at idle, hot.....
Hi Zen Mod
I bought the amp second hand so didn't build it.Therefore I'm not sure how to set the inner side of the output cap
Any help will be greatly appreciated.
Chris
Chris,
You need the pictorial build guide. Here's a screen shot of the adjustment. Multimeter to Q1 and ground. Set the pot (blue plastic square with white screw adjustment) to 15v (or whatever your target is). Keep cover on as it will be when finished. With amp on, wait half hour and adjust again.
How to replace of 2SK170 by J111
Nelson Pass mentioned Fairchild J111 being a possible substitute for 2sk170 for F5. Only $0.16 each, 73,000 parts in stock at Mouser. It seems like it would work very well in the ACA
I have exhausted my 2SK170's I got from US and am actively looking for replacement JFET's. J111 as per these comments looks like a great candidate, got them super cheap from RSDelivers.in however it doesn't look like it's an apple to apple replacement for 2SK (.. tried replacing them in my working ACA channel..including considering the leads are different for J111), but did not work...guys, need some direction/headstart to make this possible.
