UGS-muse preamp GB
Joined 2010
Hi Alex,
The resistor is 100 ohms... I take another waveform that should looks more clean
I tried other remotes and also to reprogram the remote.
The wave form is the same for all what I tried.
The +V is 3.18V. The output is normally high at 3.16V and drop at 1.8V when I send the signal.
I also rechecked the ARM but everything seems ok...I can't figure out where is the problem
Thanks and Regards,
Enrico
Ok then no problem this is the right version, V1.1 has a different pinout but nobody has some except me.
They work perfectly fine as well just the MCU pinout is a bit different so for a minute I had a doubt.
But I never shipped any so no worries.
Still I don't understand why the level is 1.8V or a logical 0...
If you remove the IR sensor do you have a 0? No short with a bad soldering to the neighborhood pin on the MCU? (89, 90, 91)
Joined 2010
I dismounted the IR and I have more or less 0,8V of the out pad.
I rechecked carefully the pins but everything looks fine. The board with the exception of the remote control is working perfectly so I would be very surprised if the problem is in the ARM.
I would like to send you a picture but I don't have a good camera with me right now...
Is this right or wrong ?
Hi Eric06 :)
I have flashed my Uc-board with firmware 2.5.
I save all my settings to: Settings 1.
Mine works O.K as long as I don´t disconnect the power-supply (Leave it in stand-by).
In stand-by all settings are there, and I can start it with the remote.
But If I disconnect the power-supply, I have to start it with the encoder switch, and restore settings 1.
Is this right /correct, or do I have a problem/fault ?
Best Regards
Johnny
Joined 2010
Bonjour Alex and Eric,
Sorry for the late reply but there are 8 hours between Korea and Europe:)
So, looking in the waveform my IR doesn't work properly. I don't have a new one, today I will order...
Alex, the 0.8V are measured in the pad of the pcb where is connected the IR output.
What should be the expected value there? I hope to do not touch the MCU
Thanks to both of you to help me in this troubleshooting... really appreciate!!
Best Regards,
Enrico
Hi Eric06 :)
Best Regards
Johnny
Hi Johnny, if you want to start directly from your saved config 1, just make a long push on input1 button instead of starting from the encoder switch.
Note: firmware is 100% Alex's coding.
