To all, this is what I use for remote for the Muse. Works like a charm:
TV Mini Keychain Universal Remote Control for Philips Sony Panasonic Toshiba Lo | eBay
Hi Algar,
You have the preamp fully assembled?
What do you think about the listening experience?
Remote
Hi Alex
Tried another old Philips remote, and it worked .
From the French forum:
A custom made remote, made out of solid aluminium with RC5 codec is on it´s way to me.
It has 10 buttons, which can be assigned as i like. From what I can read out from the display, the following "actions" can be progged:
System ID
Standby
Mute output
Volum +
Volum –
Balance left
Balance Right
Toggle output
Input 1
Input 2
Input 3
Input 4
Bypass input
Input type
Input coupling
Any idea which I should use ?
Kind Regards
Johnny
Got mine working now with an old Philips Tv remote .
Hi Alex
O.K , I will post my questions here in this forum, no problem.PS: I think moderators are not too much in favor of writing in English on the forum, I have no problem on my side to answer but we should follow the rules.
Could you post next time your questions on DIY audio UGS Muse topic? I am also answering there
Thanks.
System ID
Standby
Mute output
Volum +
Volum –
Balance left
Balance Right
Toggle output
Input 1
Input 2
Input 3
Input 4
Bypass input
Input type
Input coupling
Kind Regards
Johnny
wherever it is , it's ooking preposterous
denying ppl right to communicate , for ppl not knowing/able to use main forum language .....
on my forum, which is Serbian (language) we had plenty of correspondence on English, with members not speaking/writing Serbian
name of the game is sharing and communicating , blindness and rigidity are root of everything we see every day in bad news
Hi Alex
System ID
Standby
Mute output
Volum +
Volum –
Balance left
Balance Right
Toggle output
Input 1
Input 2
Input 3
Input 4
Bypass input
Input type
Input coupling
Kind Regards
Johnny
Hi Johnny,
It is really up to you but at least the standby (1), volume (2), mute (1), input (4) & output select (1)? That will use 9 remote keys.
BTW the binary you have is still buggy on few points, I made several improvements, I will publish a V2.4 soon.
Nobody will deny and on my side I am fine to write in English as well.
It is just a preference with the right main forum language that's it.
It is nothing about blindness or rigidity as you quote, don't worry
Hi
What is the current consuption on the 24V rail ?
Johnny
Anyone ? Min./ worst case, depending of modules implemented. Reason for asking, is that I intend to implement chokes in the power-supply.
Johnny
Johnny
Hi Johnny,
I'll do the measurement tonight for you.
what Is advantage of muse chip over relay volume pot
does anyone auditioned It
does muse chip achieve better sq
The Muse sounds better definitely.
The UGS Muse is an upgrade of the UGS AI which was relay / resistor based and it does sound better.
I had both (not anymore the AI) and this is why I created this upgrade not being completely satisfied with the UGS AI sound.
Hi Johnny,
Here we are: 33mA with the UGS, 43mA with the UGS + Buffer.
This is on one 24V rail.
- UGS-muse preamp GB
