- andrea_mori: 2 x AT 11.2896 MHz + 2 x SC 5.6448 MHz + 2 x SC 6.144 MHz + 2 x SC 12.288 MHz + 2 x SC 90.3168 MHz + 2 x SC 98.304 MHz
+ 4 x TWTMC-D + 4 x TWTMC-OVN + 2 x TWTMC-D&D
- canvas: 4*TWTMC-D, 4*TWTMC-OVN, 2 x TWTMC All-in-One (bare board), 1 x SC 22.5792 MHz, 1 x SC 24.5760 MHz
- fralippo: 8 x TWTMC-D + 8 x TWTMC-OVN + 4 x TWTMC-D&D + 1 x TWTMC AIO PCB + 1 x AT 11.2896 MHz + 1 x AT 12.288 MHz
- gabor80: 1 x TWTMC-C + 2 x TWTMC-D + 2 x TWTMC-OVN + 2 x TWTMC-DIL Dil adapter + 1 x SC 45.1584 MHz + 1 x SC 49.1520 MHz + 1 x AT 11.2896 MHz
- xaled: 6 x TWTMC-D + 6 x TWTMC-OVN + 3 x TWTMC-D&D
- MadKid: 1 x SC 90.3168 MHz + 1 x SC 98.304 MHz + 5 x TWTMC-D + 5 x TWTMC-OVN
- spm: 90.3168 MHz AT-cut x 1, 98.304 MHz AT-cut, x 1, 90.3168 MHz SC-cut x 1 ,98.304 MHz SC-cut x1 , TWTMC-D x 8, TWTMC-OVN x 4
- shendrik:1 x AT 45.1584 MHz + 1 x AT 49.1520 MHz + 1 x SC 45.1584 MHz + 1 x SC 49.1520 MHz
- tagheuer: 2 x TWTMC-OVN
- Baka: 1 x SC 22.5792 MHz
- Clsidxxl: 2 x TWTMC-D + 2 x TWTMC-OVN + 1 SC 22.5792 MHz + 1 SC 24.5760 MHz
- BDL: 1 x AT 11.2896 MHz + 1 x TWTMC-C + 3 x TWTMC-D + 4 x TWTMC-P + 1 x TWTMC-D&D + 1 x TWTMC-OVN
- duster1: 1 x SC 90.3168 MHz, 1 x SC 98.304 MHz, 8 x TWTMC-D, 2 x TWTMC-P, 1 x TWTMC-D&D, 4 x TWTMC-OVN
- triodehunter: 2 x SC-22.5792 MHz 3rd overtone, 2 x SC-24.5760 MHz 3rd overtone, 4 x TWTMC-D, 4 x TMTMC-OVN, 2 x TWTMC-D&D
- hsi68: 1 x SC 90.3168 MHz, 1 x SC 98.304 MHz, 2 x TWTMC-D, 2 x TWTMC-OVN
- Sligolad: 1 x SC 22.5792 MHz, 1 x SC 24.5760 MHz, 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 2 x TWTMC-D&D, 4 x TWTMC-D
- Crom: 1 x TWTMC All-in-One with the upgraded crystals
- rickmcinnis: 1 x TWTMC All-in-One with the upgraded crystals
- minionas: 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 2 x TWTMC-D, 2 x TMTMC-OVN, 2 x TWTMC-DIL Dil adapter, 1 x TWTMC-D&D
- crowlie 4 x AT 11.2896 MHz, 1 x SC 22.5792 MHz
- GOR3: 2 x TWTMC All-in-One (bare board), 1 x SC 22.5792 MHz, 1 x SC 24.5760 MHz
- kazap: 1 x TWTMC All-in-One completed with the upgraded crystal
- system54 1x SC 22.5792 MHz, 1x SC 24.5760 MHz, 1x AT 25.000 Mhz, 2 x TWTMC -D, 1x TWTMC -P, 2x TWTMC -D&D
- flowerpot 2 x AT 45.1584 MHz, 2 x AT 49.1520 MHz, 1 x AT 90.3168 MHz, 1 x AT 98.3040 MHz, 8 x TWTMC-D, 3 x TWTMC-D&D
- taisho_daniel 1 x TWTMC All-in-One completed, 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz
- ryanj: 1 x AT 11.2896 MHz
- twlai: 1x SC 22.5792, 1x TWTMC -D, 1x TWTMC-D&D, 1x TWTMC-OVN
- Jp85 1x TWTMC All-in-One completed. 2X TWTMC Dil adapter
- SPWONG: 1 x AT 11.2896 MHz
- grael: 1 x TWTMC All-in-One completed with the upgraded crystals (and uFl connectors)
- sts9: 1 x AT 45.1584 MHz, 1 x AT 49.1520 MHz, 2 x TWTMC-D, 1 x TWTMC-D&D
- ambrosia168: 1 x SC 24.5760 MHz, 1 x SC 90.3168 MHz, 1 x TWTMC-OVN
- lindamar: 4 x TWTMC-D + 4 x TWTMC-OVN + 2 x TWTMC-D&D + 4 TWTMC-DIL
- ppap64: 4 x TWTMC-D + 4 x TWTMC-OVN + 4 x TWTMC-D&D + 4 TWTMC-DIL + 1 x SC 45.1584 MHz + 1 X SC 49.1520 MHz
update order
update order
Closing the GB
Hi all,
I would finalize the new order to Laptech, so I ask members who have not yet sent me the order form to download and send me it filled.
Following the summary of each requested part:
For the following frequencies, the MOQ was met (not yet received all the orders):
SC-cut 11.2896 MHz (10)
SC-cut 22.2792 MHz (14)
SC-cut 24.5760 MHz (11)
SC-cut 45.1584 MHz (10)
SC-cut 49.1520 MHz (10)
AT-cut 11.2896 MHz (14)
AT-cut 25.0000 MHz (2) in stock
For the following frequencies, the MOQ was not met:
SC-cut 5.6448 MHz (4), MOQ 15 pcs
SC-cut 6.1440 MHz (2), MOQ 15 pcs
SC-cut 12.2880 MHz (2), MOQ 10 pcs
SC-cut 90.3168 MHz (6), MOQ 15 pcs
SC-cut 98.3040 MHz (5), MOQ 15 pcs
AT-cut 22.2792 MHz (4), MOQ 10 pcs
AT-cut 24.5760 MHz (4), MOQ 10 pcs
AT-cut 45.1584 MHz (3), MOQ 10 pcs
AT-cut 49.1520 MHz (3), MOQ 10 pcs
AT-cut 90.3168 MHz (2), MOQ 15 pcs
AT-cut 98.3040 MHz (2), MOQ 15 pcs
TWTMC-AIO (7), MOQ 100 pcs
I think there is no chance to meet the MOQ for SC at 5.6448, 6.144 and 12.288 MHz, so these crystals are not available.
MOQ was not met for AT 22.5792, 24.576, 45.1584 and 49.152 MHz, so who is still interested in the above frequencies please move your order to SC-Cut type at the same frequencies (MOQ was met).
About 90/98 MHz crystals, MOQ was not met for AT and SC crystals, so please move your order anyway to SC type, then we will see if there will be more interest in the next days.
About the TWTMC-AIO the interest is far from the MOQ requested (100 pcs), so I could provide the bare PCB and the crystals.
Andrea
Hi all,
Andrea
Hello Andrea,(...)
Andrea
Does it mean that you won't be able to provide the TWTMC-AIO completed with upgraded crystals? (Which, if I'm not mistaken, are the AT-cut I spotted above)
Thanks anyway for your efforts
[Edit] Ok, I read better, the MOQ for completed TWTMC-AIO was 100 and is not met. Am I right?
Hi all,
Andrea
So, perhaps there is a chance for met MOQ for:
if so, I'm interested in and I and would change my previous 44/49 MHz AT-cut crystals to 22/24 MHz AT-cut crystals:
AT-cut 22.2792 MHz (5), MOQ 10 pcs
AT-cut 24.5760 MHz (5), MOQ 10 pcs
Hello Andrea,
the problem is that is not possible to use SMT line for 7 boards, I calculated the total cost for 100 pcs break price, parts and SMT assembly.
There are 2 options:
1) I supply only bare PCB and crystals
2) I supply manual assembled boards revising the price
Anyway, if MOQ for AT 22/24 MHz will be not met I will replace the crystals with SC cut type at the same frequencies and at its higher price.
Members who are interested on the finished TWTMC-AIO, please let me know what do you think about.
Yes, you can update your order, but as I said above, if MOQ for AT 22/24 MHz will be not met, the only chance is to move to SC-Cut type.
- twlai: 1x SC 22.5792, 1x SC 49.1520, 2x TWTMC -D, 2x TWTMC-D&D, 2x TWTMC-OVN
update order
update order
Fair enough.Hi,
I suck at soldering surface mount components so I would be interested in your manual completed offer (if it's not to much hassle for you, and if the revised price is still reasonable)
I hope enough interested members will stay with the AT crystal to meet the MOQ, SC cut kind of require using the oven board if I understood correctly
Hi Andrea,
I just found out about your group buy and would like to jump in if it is still possible.
I'm interested in TWTMC-AIO PCB with 45.1584 MHz and 49.1520 MHz crystals. I would like to use it with Ian's FIFO kit as a possible replacement of my present Crystek clocks. Is this board suitable to be directly used in this application? Since it seems that AT cut crystals will not reach MOQ, can this board be directly used with SC cut crystals? Is the oven improving the performance of SC crystals a lot and if yes than can the TWTMC-AIO be used with two ovens on top of it?
Martin
Martin
- Jp85 1x TWTMC-D&D,2X TWTMC Dil adapter, 2xTWTMC-D, 1xTWTMV-Ovn, 1xAt-cut 22.5729 x 1xSc-cut 22.5760
updated my odrer becausecit doesn't look like the assembled AIO,board,assembled,is not going to get the required moq
Hi Andrea,
Martin
Yes, you can use all these oscillators with Ian's Fifo, I'm using the TWTMC-D Driscoll osc with Ian's stuff. You can also use the AIO board.
AIO board can be used with SC-Cut crystals, but I have to check the mechanical fitting of two ovens on the top of the board. I will check and let you know.
About the oven in digital audio, if you read previous posts, there are two school of thought, someone think it's an improvement, others think it's unuseful. Personally I prefer to use the oven, but it's only my subjective opinion.
- Malvin: 1 x AT 11.2896 MHz, 1 x TWTMC-P, 2 x TWTMC All-in-One (bare board), 2 x TWTMC-OVN, 2 x TWTMC-D, 4 x TWTMC-DIL Dil adapter, 1 x TWTMC-D&D
- sts9: 1 x AT 22.5792 MHz, 1 x AT 24.5760 MHz, 2 x TWTMC-D, 1 x TWTMC-D&D
update my order.
update my order.
- grael: 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 2 x TWTMC-AIO bare PCB
From AIO completed to bare boards (and different crystals)
- jptz: 1 x TWTMC All-in-One with the upgraded crystals
- Carmaux: 1 x SC 22.5792 MHz, 1 x SC 24.5760 MHz, 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 8 x TWTMC-D, 4 x TWTMC-OVN
- Superberg: 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 1 x TWTMC-AIO, 2 x TWTMC-OVN, 4 x TWTMC-DIL
Hi Andrea,
Martin
The only chance to fit two ovens is to place crystals and ovens on the bottom side of the PCB, leaving connectors and components on the top side like in the attached picture (please consider the AIO board reversed with crystals on the bottom side).
I'm revising the price of the finished TWTMC-AIO hand assembled, with Laptech crystals only (no chance to get the cheaper crystal for such low quantity).
Since there are many members asking fo finished boards (all oscillators and optional parts), next days I will provide the price for each finished and tested boards, including the TWRPS-pp micro regulators.
Update: available parts and Order Form including finished boards
Following the list of the available parts and their prices.
Laptech crystals AT-Cut and SC-Cut in HC-43/U cold welded package
TWTMC-C Colpitts-Clapp AT-Cut crystal oscillator board suitable for frequencies from 5 MHz up to 50 MHz (finished and bare board)
TWTMC-D Driscoll AT-Cut and SC-Cut crystal oscillator board suitable for frequencies from 5 MHz up to 100 MHz (finished and bare board)
TWTMC-P Pierce AT-Cut crystal oscillator board suitable for frequencies from 5 MHz up to 100 MHz (finished and bare board)
TWTMC-AIO All in One dual Driscoll crystal oscillator with shunt regulators (finished and bare board)
TWTMC-D&D Daughter board that accommodates two oscillators and provides power supply, dividers, clock delay and switching logic between the two oscillators (finished and bare board)
TWTMC-OVN Oven board for Driscoll SC-Cut crystal oscillator (finished and bare board)
TWTMC-DIL DIL adapter for Ian's dual clock board (finished and bare board)
AT-cut crystal
5.6448 MHz fundamental MOQ 15 pcs Eur 29.00 each
6.1440 MHz fundamental MOQ 15 pcs Eur 29.00 each
11.2896 MHz fundamental MOQ 10 pcs Eur 27.00 each
12.2880 MHz fundamental MOQ 10 pcs Eur 27.00 each
16.9344 MHz fundamental MOQ 10 pcs Eur 27.00 each
22.5792 MHz fundamental MOQ 10 pcs Eur 27.00 each
24.5760 MHz fundamental MOQ 10 pcs Eur 27.00 each
25.0000 MHz fundamental MOQ 10 pcs Eur 27.00 each
45.1584 MHz 3rd overtone MOQ 10 pcs Eur 27.00 each
49.1520 MHz 3rd overtone MOQ 10 pcs Eur 27.00 each
90.3168 MHz 5th overtone MOQ 15 pcs Eur 29.00 each
98.3040 MHz 5th overtone MOQ 15 pcs Eur 29.00 each
SC-cut crystal
5.6448 MHz fundamental MOQ 15 pcs Eur 45.00 each
6.1440 MHz fundamental MOQ 15 pcs Eur 45.00 each
11.2896 MHz 3rd overtone MOQ 15 pcs Eur 38.00 each
22.5792 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
24.5760 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
45.1584 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
49.1520 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
90.3168 MHz 5th overtone MOQ 15 pcs Eur 56.00 each
98.3040 MHz 5th overtone MOQ 15 pcs Eur 56.00 each
PCB
TWTMC-C Colpitts-Clapp oscillator Eur 3.00 each
TWTMC-D Driscoll oscillator Eur 3.00 each
TWTMC-P Pierce oscillator Eur 3.00 each
TWTMC-AIO All in One bare PCB Eur 6.00 each
TWTMC-D&D Daughter board Eur 10.00 each
TWTMC-OVN Oven Eur 3.00 each
TWTMC-DIL Dil adapter Eur 2.00 each
Finished boards
TWTMC-AIO All in One finished board without crystals and connectors Eur 95.00 each
Pin strip connector Soldered 1 x pin strip output connector Eur 1.5 each
U.fl connector Soldered 1 x u.fl output connector Eur 3.00 each
SMA connector Soldered 1 x SMA output connector Eur 5.5 each
PS pin strip connector Soldered pin strip power supply connector Eur 2.00 each
PS screw connector Soldered header screw terminal block power supply connector Eur 3.00 each
TWTMC-C Finished Colpitts-Clapp oscillator without crystals and connectors Eur 52.00 each
TWTMC-D Finished Driscoll oscillator without crystals and connectors Eur 59.00 each
TWTMC-P F inished Pierce oscillator without crystals and connectors Eur 44.00 each
Potato upgrade 1 x Potato Semi PO74GU04A/PO74G74A slicer/divider upgrade Eur 4.00 each
TWTMC-OVN Finished oven for SC-Cut crystals Eur 63.00 each
TWTMC-DIL Finished Dual in Line adapter without connectors Eur 8.00 each
TWTMC_D&D RF Finished daughter board - Rectification and filtering only without connectors Eur 45 each
TWTMC_D&D RF REG Finished daughter board - Rectification, filtering and regulators without connectors Eur 90.00 each
TWTMC_D&D RF REG SW Finished daughter board - Rectification, filtering, regulators and switching logic w.c. Eur 145.00 Each
TWTMC_D&D RF REG SW DD Finished daughter board - Rect., filt., regs, switching logic and dividers/delay w.c. Eur 170.00 each
TWRPS-pp micro Finished push-pull regulator 6V or 5V or 3V3 Eur 98.00 Each
AT-cut crystal
SC-cut crystal
PCB
Finished boards
I have updated the order form including finished boards.
Please, who asked for TWTMC-AIO and Assembly Service should download the new order form and send me it filled.
Since one would choice his own input and output connectors, all the finished boards don't include any connectors, so you should add the desired connectors as optional parts.
I think we can meet easily the MOQ for 22/24 MHz AT-Cut crystals, so the TWTMC All in One can be supplied with AT Crystals at these frequencies, avoiding the complication of the 2 ovens.
Please, who is in the interesting list but has not yet sent me the Order Form, download, fill and send me it as soon as possible.
Keep in mind that crystals and bare boards will be shipped as soon as I will receive them from the manufacturers, while about the finished boards it will take more time because I have to order all the parts and manually build each board, with my little free time. So, expect at least one month after I will receive the parts.
- Group Buys
- The Well Tempered Master Clock - Group buy
