- andrea_mori: 2 x AT 11.2896 MHz + 2 x SC 5.6448 MHz + 2 x SC 6.144 MHz + 2 x SC 12.288 MHz + 2 x SC 90.3168 MHz + 2 x SC 98.304 MHz +
4 x TWTMC-D + 4 x TWTMC-OVN + 2 x TWTMC-D&D
- canvas: 2*TWTMC-D, 2*TWTMC-OVN
- fralippo: 8 x TWTMC-D + 8 x TWTMC-OVN + 4 x TWTMC-D&D
- gabor80: 2 x TWTMC-D + 2 x TWTMC-OVN + 2 x TWTMC-DIL Dil adapter + 1 x SC 45.1584 MHz + 1 x SC 49.1520 MHz
- xaled: 6 x TWTMC-D + 6 x TWTMC-OVN + 3 x TWTMC-D&D
- MadKid: 1 x SC 90.3168 MHz + 1 x SC 98.304 MHz + 5 x TWTMC-D + 5 x TWTMC-OVN
-spm: 90.3168 MHz AT-cut x 1, 98.304 MHz AT-cut, x 1, 90.3168 MHz SC-cut x 1 ,98.304 MHz SC-cut x1 , TWTMC-D x 8, TWTMC-OVN x 4
-shendrik:1 x AT 45.1584 MHz + 1 x AT 49.1520 MHz + 1 x SC 45.1584 MHz + 1 x SC 49.1520 MHz
- tagheuer: 2 x TWTMC-OVN
- Baka: 1 x SC 22.5792 MHz
- Clsidxxl: 2 x TWTMC-D + 2 x TWTMC-OVN + 1 SC 22.5792 MHz + 1 SC 24.5760 MHz
- BDL: 1 x AT 11.2896 MHz + 1 x TWTMC-C + 3 x TWTMC-D + 4 x TWTMC-P + 1 x TWTMC-D&D + 1 x TWTMC-OVN
- duster1: 1 x SC 90.3168 MHz, 1 x SC 98.304 MHz, 8 x TWTMC-D, 2 x TWTMC-P, 1 x TWTMC-D&D, 4 x TWTMC-OVN
- triodehunter: 1 x SC-22.5792 MHz 3rd overtone, 1 x SC-24.5760 MHz 3rd overtone, 2 x TWTMC-D, 2 x TMTMC-OVN, 1 x TWTMC-D&D
- hsi68: 1 x SC 90.3168 MHz, 1 x SC 98.304 MHz, 2 x TWTMC-D, 2 x TWTMC-OVN
- Sligolad: 1 x SC 22.5792 MHz, 1 x SC 24.5760 MHz, 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 2 x TWTMC-D&D
- Crom: 1 x TWTMC All-in-One with the upgraded crystals
- rickmcinnis: 1 x TWTMC All-in-One with the upgraded crystals
- minionas: 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 2 x TWTMC-D, 2 x TWTMC-DIL Dil adapter
updated mine
- minionas: 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 2 x TWTMC-D, 2 x TMTMC-OVN, 2 x TWTMC-DIL Dil adapter
final update
- minionas: 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 2 x TWTMC-D, 2 x TMTMC-OVN, 2 x TWTMC-DIL Dil adapter, 1 x TWTMC-D&D
- crowlie 4 x AT 11.2896 MHz
- GOR3: 2 x TWTMC All-in-One (bare board), 1 x SC 22.5792 MHz, 1 x SC 24.5760 MHz
Update my list.
- canvas: 4*TWTMC-D, 4*TWTMC-OVN, 2 x TWTMC All-in-One (bare board), 1 x SC 22.5792 MHz, 1 x SC 24.5760 MHz
+ 4 x TWTMC-D + 4 x TWTMC-OVN + 2 x TWTMC-D&D
- spm: 90.3168 MHz AT-cut x 1, 98.304 MHz AT-cut, x 1, 90.3168 MHz SC-cut x 1 ,98.304 MHz SC-cut x1 , TWTMC-D x 8, TWTMC-OVN x 4
- shendrik:1 x AT 45.1584 MHz + 1 x AT 49.1520 MHz + 1 x SC 45.1584 MHz + 1 x SC 49.1520 MHz
- kazap: 1 x TWTMC All-in-One completed with the upgraded crystal
- fralippo: 8 x TWTMC-D + 8 x TWTMC-OVN + 4 x TWTMC-D&D + 1 x TWTMC AIO PCB + 1 x AT 11.2896 MHz + 1 x AT 12.288 MHz
- system54 1x SC 22.5792 MHz, 1x SC 24.5760 MHz, 1x AT 25.000 Mhz, 2 x TWTMC -D, 1x TWTMC -P, 2x TWTMC -D&D
- flowerpot 2 x AT 45.1584 MHz, 2 x 49.1520 MHz, 1 x AT 90.3168 MHz, 1 x AT 98.3040 MHz, 6 x TWTMC-D, 3 x TWTMC-D&D, 4 x TWTMC-DIL
- taisho_daniel 1 x TWTMC All-in-One completed, 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz
Update: available parts and Order Form
Following the list of the available parts and their prices.
Laptech crystals AT-Cut and SC-Cut in HC-43/U cold welded package
TWTMC-C Colpitts-Clapp AT-Cut crystal oscillator board suitable for frequencies from 5 MHz up to 50 MHz
TWTMC-D Driscoll AT-Cut and SC-Cut crystal oscillator board suitable for frequencies from 5 MHz up to 100 MHz
TWTMC-P Pierce AT-Cut crystal oscillator board suitable for frequencies from 5 MHz up to 100 MHz
TWTMC-AIO All in One dual Driscoll crystal oscillator with shunt regulators (finished and bare board)
TWTMC-D&D Daughter board that accommodates two oscillators and provides power supply, dividers, clock delay and switching logic between the two oscillators
TWTMC-OVN Oven board for Driscoll SC-Cut crystal oscillator
TWTMC-DIL DIL adapter for Ian's dual clock board
AT-cut crystal
5.6448 MHz fundamental MOQ 15 pcs Eur 29.00 each
6.1440 MHz fundamental MOQ 15 pcs Eur 29.00 each
11.2896 MHz fundamental MOQ 10 pcs Eur 27.00 each
12.2880 MHz fundamental MOQ 10 pcs Eur 27.00 each
16.9344 MHz fundamental MOQ 10 pcs Eur 27.00 each
22.5792 MHz fundamental MOQ 10 pcs Eur 27.00 each
24.5760 MHz fundamental MOQ 10 pcs Eur 27.00 each
25.0000 MHz fundamental MOQ 10 pcs Eur 27.00 each
45.1584 MHz 3rd overtone MOQ 10 pcs Eur 27.00 each
49.1520 MHz 3rd overtone MOQ 10 pcs Eur 27.00 each
90.3168 MHz 5th overtone MOQ 15 pcs Eur 29.00 each
98.3040 MHz 5th overtone MOQ 15 pcs Eur 29.00 each
SC-cut crystal
5.6448 MHz fundamental MOQ 15 pcs Eur 45.00 each
6.1440 MHz fundamental MOQ 15 pcs Eur 45.00 each
11.2896 MHz 3rd overtone MOQ 15 pcs Eur 38.00 each
22.5792 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
24.5760 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
45.1584 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
49.1520 MHz 3rd overtone MOQ 10 pcs Eur 38.00 each
90.3168 MHz 5th overtone MOQ 15 pcs Eur 56.00 each
98.3040 MHz 5th overtone MOQ 15 pcs Eur 56.00 each
Boards
TWTMC-C Colpitts-Clapp oscillator Eur 3.00 each
TWTMC-D Driscoll oscillator Eur 3.00 each
TWTMC-P Pierce oscillator Eur 3.00 each
TWTMC-AIO All in One bare PCB Eur 6.00 each
TWTMC-D&D Daughter board Eur 10.00 each
TWTMC-OVN Oven Eur 3.00 each
TWTMC-DIL Dil adapter Eur 2.00 each
Finished boards
TWTMC-AIO All in One finished board without connectors Eur 60.00 each
TWTMC-AIO All in One upgrade to Laptech HC-43/U AT-Cut crystals (22.5792 and 24.576 MHz) Eur 60.00 both crystal soldered
TWTMC-AIO All in One pin strip output connectors Eur 3.00 both connectors soldered
TWTMC-AIO All in One u.fl output connectors Eur 6.00 both connectors soldered
TWTMC-AIO All in One SMA output connectors Eur 11.00 both connectors soldered
TWTMC-AIO All in One pin strip power supply connector Eur 2.00 each
TWTMC-AIO All in One header screw terminal block power supply connector Eur 3.00 each
AT-cut crystal
SC-cut crystal
Boards
Finished boards
Hi Andrea,
For those of us that ordered via email using the forms, when can we expect bills to be sent and the group buy shipping to commence?
-Raja
The GB is still open, MOQ have to be reached, so it's difficult to say when items will be shipped. Anyway you can expect at least one month or two.
- Sligolad: 1 x SC 22.5792 MHz, 1 x SC 24.5760 MHz, 1 x SC 45.1584 MHz, 1 x SC 49.1520 MHz, 2 x TWTMC-D&D, 4 x TWTMC-D
Updated my order with Driscoll boards.
- gabor80: 1 x TWTMC-C + 2 x TWTMC-D + 2 x TWTMC-OVN + 2 x TWTMC-DIL Dil adapter + 1 x SC 45.1584 MHz + 1 x SC 49.1520 MHz + 1 x AT 11.2896 MHz
I update my order too.
- flowerpot 3 x AT 45.1584 MHz, 3 x AT 90.3168 MHz, 1 x AT 98.3040 MHz, 10 x TWTMC-D, 2 x TWTMC-D&D
Update
Update
- Group Buys
- The Well Tempered Master Clock - Group buy
