DAC-END R (ES9018) full assembled board
So now DAC running... BUT :
I got one question regarding the legato...
Iḿ using an quanghau design DAC together with the legato I/V stage....
After startup the USB is active, and when I switch to optical input I can see that signal is locked, but there is no sound coming from the legato.
After switching off and on the legato stage, there is sound. Do u have an idea why this is ?
May be the iv have prolem.
The iv get I out or v out from dac? Please tell me now .
Hi, I am finally back and have time to enjoy and play with my DACENDR. The firmware didn't really solved the issue of the first 0.5s mute, but I can live with it. Now I am having another query:
1. I connect the DAC to headphone amp for listening and the right hand side has an audible hum when i turn up the vol to max. the left side too , but less audible.
2. I notice some of the transistor in the shunt regulations are FZT957, while a few were hand soldered with FZT953. Have check the datasheet of these 2 transistors and the parameters are quite different. Has this got anything to do with the hum noise?
About using ES9018 dac with zapfilter 2
What are your experience with this setup?
What type of output are you guys using (voltage or current from the dac)?
I am using balanced current output right now and if I test with squeezebox 3 I need to have the volume at max 95% else I get a distortet output (also same thing with a DVD player connected to the zapfilter 2 (all coax)
Could It be any difference if I connect the dac output as voltage single to the zapfilter 2?
Best regards
Best regards
I use Voltage. Much more dynamic then Current output.
Best regards
Hi.
The distortion issue with max 95% may be the ES9018 has VACC/2 on output (3,3V/2=1,65V). Have you raised the input of the Zap-filter to the same?
Also be aware that the Zap filter is made for DAC with much lower current then the ES9018. I would contact LCAudio for advise when using this DAC chip.
Br
Caad
Hi.
Br
Caad
How do I raise the input to handle the current output?
Thanks☺
Well I finally assembled my version-1 DAC-END-R, with Lundahl transformer output boards.
Sadly, not working.
With original firmware, I tried coax input (CD player) and optical input (TV). In both cases the display remained on "DSD" and no audio output.
Then I flashed the firmware to ver 57a. Slight change - now the display remains on "PCM" but still no audio output. I tried coax input, optical input, and also I2S input from Beaglebone Black. With each input, When I toggle from menu-mode back to normal-mode, I see "PCM-/0)-Hz" displayed.
It seems the DAC does not recognise the incoming digital data?
Andrea suggested I use firmware 64a. I flashed this firmware. No change.
Andrea suggested I check the ribbon cable and its connections. I removed the controller, tested the ribbon cable with multi-meter, re-soldered 2x connections at the controller. No change.
Is there anything else I can check, please?
