News...
QUASI PURE SINE
QUASI PURE SINE
For best results one should use "prime frequencies" of the FFT size, and no FFT window, of course. This is also intrinsically self-dithering.
No sample value ever occurs twice in the whole sequence (FFT size) but the sequence itself must repeat perfectly (for the non-windowing to work).
This is whole idea and recipe for the construction.
Unfortunately the maths are simple but few get it. A 1kHz sine wave sampled at 96kHz uses only 96 codes of which only 48 are unique. No dither is necessary because the values and time samples are exact since this is a closed numerical exercise.
96K sine resampled to 44K sine with dither, in this case dither increase the codes ?
Don't Get Lost in the Noise Floor PDF
http://www.analog.com/media/en/training-seminars/tutorials/MT-003.pdf
Don't Get Lost in the Noise Floor[/IMG]
You means to analyze something like this...
Hp
I have written a custom macro to explore the noise floor at various frequencies,
This macro creates a auto-text txt file which contains all the results.
see this video on youtube
https://youtu.be/XmQ9iyqh4XA
This is the video of noise floor at 20 KHz - 90 Khz range (HD?)
https://youtu.be/faGUJ3XyXNI
Arta
(UP) 24bit + Dither
(DOWN) 24bit - Dither
(UP) 24bit + Dither
ah, ok, filtered and this is my max lower floor
Hp
But your software is a 'real-time' like Spectraplus or is a 'only reading files ?
- Sound Card realtime MME, WDM, ASIO Sync I/O, ASIO Multi Client, WASAPI Exclusive Input & Output and also on ASIO 2x..8x speed (channel bundling)
- Analise Wave Files
- Analise Text Files
- Wave Generator with various signals
- Level, Power, Spectrum Density, Fast Freq. Response
http://www.diyaudio.com/forums/vendors-bazaar/157053-ann-hpw-works-v3-0-pc-based-measurement-system.htmlhttp://
Or download PDF and read on or simple download the evaluation SW for the the homepage
Hp
i have downloaded your trial software for evalutating my noisefloor ,- Sound Card realtime
Hp
I'm probably rusty, but I have not managed to use it and see my noisefloor in realtime in any way
In case of any difficulties please, as usual, contact the given support channel with related information(s)
Hp
I was plotting the output of external signal generator (like Viktors) over an analog connection input with ASIO driver.
My audio chipset is from
1) Generic Laptop with internal Asus Soundcard (16 bit)
2) Generic PC with external RME Audio Soundcard (24 bit)
3) Generic PC with internal Lynx AES16e Soundcard (24 bit)
my low THD soundcard is the AES16e = -140 flat
Thanks for the replies guys. I can playback and record 96/24 over SPDIF bit perfect. I will give it a go and compare the sines here to the rme sine below.
There are some free 0.001 THD+n sines here too:
RME Intelligent Audio Solutions - Audio Test Files
- Design & Build
- Software Tools
- Extreme pure sine (0.0007% THD+N)
